skunk 2 ecu program
Old Apr 11, 2005 | 06:34 PM
phantom grey eg's Avatar
Default skunk 2 ecu program
i am considering getting the skunk 2 ecu program, i tried to search on here but got nothing, i am just wondering if anybody has ran it, or heard good/bad things about it. any help is greatly appreciated. thank you in advance.
Old Apr 25, 2005 | 06:25 PM
Tyreece04's Avatar
Default Re: skunk 2 ecu program (phantom grey eg)
The Skunk 2 ECU is a great investment. I had a one in my honda and couldnt believe the punch it gave me. This ECU is the only one to go with because the reliable name. The Vtec kicks in very hard and i do recomend the controller it helped me a bunch. If you have everything which calls for it it will bring out your car. Evrything else you ever put on it will actaully gain more than it would if you kept the stock ECU. If you have all stock internals rev to 8500 rpm. This is the peak hp spot. buy it its worth every penny. Easy hook up.
Old Apr 25, 2005 | 06:42 PM
93turbo16's Avatar
Why not actualy get something tuned for your motor?
Old Apr 25, 2005 | 08:46 PM
sickerhatch's Avatar
Default Re: (93turbo16)
ive got the sk2 program and its good but it dumps a lot of fuel be careful
Old Apr 27, 2005 | 07:37 PM
ironcheftony's Avatar
yea skunk2 program will eat ur gas
Old Apr 27, 2005 | 07:56 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">Why not actualy get something tuned for your motor?</TD></TR></TABLE>
Seriously. That program sucks. It's a hack of the Mugen ROM.
You will get:
knock sensor disabled
ELD disabled
No VTEC speed check
No VTEC oil pressure check
o2 sensor disabled
closed loop disabled
PA sensor disabled
You will have shitty fuel economy because the ECU will be running directly off of maps that are way too rich. o2 sensor AFR correction is disabled. There are very few engine safeguards still left in place.
Old Apr 28, 2005 | 02:17 PM
Default Re: (Jim Truett)
not cool, thanks for the info, im not going to get that then
Old Apr 28, 2005 | 02:39 PM
Katman's Avatar
Default Re: (phantom grey eg)
you can use the aide of a either an SFC VTEC/Fuel controller or APEXI VAFC to adjust the rich skunk fuel maps...best done on the dyno of course..
Old Apr 28, 2005 | 04:09 PM
Jim Truett's Avatar
Default Re: (Katman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">you can use the aide of a either an SFC VTEC/Fuel controller or APEXI VAFC to adjust the rich skunk fuel maps...best done on the dyno of course..</TD></TR></TABLE>
True. But:
1. His ECU will still be stuck in open loop
2. The fuel controller will cost an additional $200+, money that could be used towards a EPROM programmer and the other associated hardware to use Crome or Uberdata.
Old Apr 28, 2005 | 05:37 PM
my exact thoughts, for the cost of the s2 ecu and the fuel controller i could run hondata
Old Apr 29, 2005 | 07:40 AM
Katman's Avatar
true to all that, just a suggestion got dammit!
Old May 1, 2005 | 06:08 PM
lol i know man, thanks though
kNOwLedGeDA9
Oct 5, 2005 07:03 PM
Littlegreend15
Jul 16, 2005 04:51 AM
ThrillaKilla
Mar 11, 2003 05:43 PM
gearhead313
Sep 7, 2002 04:12 PM
