Tial 44mm wg+Full Race Mani = Boost Spike!!!??
Old Nov 20, 2004 | 03:38 PM
b00stedbyFastrax's Avatar
Default Tial 44mm wg+Full Race Mani = Boost Spike!!!??
already did a search. now, i have a Tial 44mm WG with a 1.0 bar spring on a Full Race Manifold. Off the WG spring boost hits 23 psi. WTF!!! there are no leaks anywhere and the Boost Controller is set up properly. what could be the problem?
Old Nov 20, 2004 | 03:42 PM
B18C1CYA's Avatar
Default Re: Tial 44mm wg+Full Race Mani = Boost Spike!!!?? (b00stedbyFastrax)
what size line are you running ??
Old Nov 20, 2004 | 03:54 PM
Jared's Avatar
Default Re: Tial 44mm wg+Full Race Mani = Boost Spike!!!?? (B18C1CYA)
how are your lines hooked up the boost controller and gate, does it spike without the controller? what boost controller?
Old Nov 20, 2004 | 04:29 PM
LostSolVTEC's Avatar
Default Re: Tial 44mm wg+Full Race Mani = Boost Spike!!!?? (Jared)
do you have the vacuum lines hooked up right? The vacuum line goes to the bottom port, and the boost controller goes to the top port
Old Nov 20, 2004 | 05:11 PM
SpoolnG2's Avatar
Default Re: Tial 44mm wg+Full Race Mani = Boost Spike!!!?? (LostSolVTEC)
take the boost controller completely out of the picture and just hook the bottom port of the wastegate up to the port on the turbo. I guarentee all you see is 1 bar. If it still goes to 23 psi after you do that, then we've got problems.....but give that a shot first.
Old Nov 20, 2004 | 06:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote">what size line are you running ??</TD></TR></TABLE>
both lines from wg is 6mm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">how are your lines hooked up the boost controller and gate, does it spike without the controller? what boost controller?</TD></TR></TABLE>
top port goes to bc. side port is tee'd off to the compressor and bc. yes it is spiking with the bc off. profec A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 &raquo;</TD></TR><TR><TD CLASS="quote">take the boost controller completely out of the picture and just hook the bottom port of the wastegate up to the port on the turbo. I guarentee all you see is 1 bar. If it still goes to 23 psi after you do that, then we've got problems.....but give that a shot first.</TD></TR></TABLE>
i'll try that
Old Nov 20, 2004 | 07:38 PM
RMF
Guest
Posts: n/a
Do you have any kind of a regulator with a gauge that goes from 0-30 or so? If hooking it up direct doesn't fix it .Check the spring pressure with the regulator.Just
turn it in untill the gate opens then look at how much pressure it took to open it.
Old Nov 20, 2004 | 07:58 PM
Blown90hatcH's Avatar
https://honda-tech.com/zerothread?id=976704
Also, what size turbo are you running?
Old Nov 20, 2004 | 08:20 PM
Killer_B's Avatar
broken diaphram?
your best bet is to contact Tial directly. they're helping me with some issues that i have with my 40mm Wg.
btw, i know someone else with a 44mm that is having problems. i'm almost ready to give up on Tial Wg's. i also had a problem with my 38mm as well.
Old Nov 20, 2004 | 08:51 PM
Default Re: Tial 44mm wg+Full Race Mani = Boost Spike!!!?? (Blown90hatcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=976704
Also, what size turbo are you running?</TD></TR></TABLE>
PT 67
Old Nov 20, 2004 | 10:40 PM
y is the side port T'd off into the boost controller line and turbo housing?
try giving it it's own vacuum source instead and see what happens. I was told that the port on the turbo should only be used if there is no boost controller by Geoff at Full-Race
Old Nov 21, 2004 | 09:03 AM
Killer_B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LostSolVTEC &raquo;</TD></TR><TR><TD CLASS="quote">y is the side port T'd off into the boost controller line and turbo housing?
try giving it it's own vacuum source instead and see what happens. I was told that the port on the turbo should only be used if there is no boost controller by Geoff at Full-Race</TD></TR></TABLE>
its only suppose to be T'd off when using Electronic or certain manual boost controllers. i don't know why its T'd off but i know the effects.
it helps Spool the Turbo faster by keeping the wastegate closed until it reachs the desired boost, then it opens. spool time is increased by at least 800rpm.
Old Nov 21, 2004 | 09:38 AM
Default Re: Tial 44mm wg+Full Race Mani = Boost Spike!!!?? (Killer_B)
do you have any pictures of the setup, i'm curious of the T'd off line now if it increases spool time
Old Nov 23, 2004 | 12:04 PM
SpoolnG2's Avatar
just curious if my suggestion worked for you or not?
Old Nov 23, 2004 | 01:06 PM
Default Re: Tial 44mm wg+Full Race Mani = Boost Spike!!!?? (SpoolnG2)
[QUOTE=SpoolnG2]just curious if my suggestion worked for you or not?[/QUOTE
haven't had the time to try it.
Old Nov 23, 2004 | 05:05 PM
Default Re: Tial 44mm wg+Full Race Mani = Boost Spike!!!?? (b00stedbyFastrax) Updated!!!
well, checked the WG with compress air. the WG began to open when it saw 20psi. so i opened the WG and checked the springs. there was a small red and a large red spring which ='s more than 1.0 bar. On the box Tial stated it was a 1.0 bar WG
go figure. anyways, used the large red spring and it took approx. 14.5 psi to get the WG to open. From what i gathered, there are probaly bad WG springs giving wrong spring pressures. i have already notified the person who deals with Tial and hopefully he will bring this to their attention.
Old Nov 23, 2004 | 06:08 PM
Default Re: Tial 44mm wg+Full Race Mani = Boost Spike!!!?? (b00stedbyFastrax) Updated!!! (b00stedbyFastrax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b00stedbyFastrax &raquo;</TD></TR><TR><TD CLASS="quote">well, checked the WG with compress air. the WG began to open when it saw 20psi. so i opened the WG and checked the springs. there was a small red and a large red spring which ='s more than 1.0 bar. On the box Tial stated it was a 1.0 bar WG
go figure. anyways, used the large red spring and it took approx. 14.5 psi to get the WG to open. From what i gathered, there are probaly bad WG springs giving wrong spring pressures. i have already notified the person who deals with Tial and hopefully he will bring this to their attention.</TD></TR></TABLE>
So the large red spring yielded approx 14.5psi gauge pressure? That is correct then. Because you have to remember that there is no exhaust gages aiding in the spring opening when you apply just the compressor air into the wastegate.
turbosol18
Sep 3, 2007 01:19 PM
faSHOwidIT
Jan 31, 2007 03:51 PM
importboi22
May 20, 2004 04:43 AM
boostdB16a
Jul 8, 2003 06:10 PM
Duck Sauce
Jul 19, 2002 01:18 AM
