vaccum source for wastegate?
Old May 19, 2004 | 06:35 PM
importboi22's Avatar
Default vaccum source for wastegate?
where would i get this at i was thinking right before the turbo/intake part
Old May 19, 2004 | 06:43 PM
xenocron's Avatar
Default Re: vaccum source for wastegate? (importboi22)
Wastegate doesnt need a vacuum source...only needs a source that shows it boost.
T it into any vacuum source from the Intake Manifold (because they will see boost as well) or hook it up to the nipple on your turbo.
Old May 19, 2004 | 06:52 PM
mademan2723's Avatar
Default Re: vaccum source for wastegate? (xenocron)
T into the brake booster line which is the huge vacum line coming out from the drivers side firewall into the IM.
Old May 19, 2004 | 07:28 PM
i know but there is one side that says BOOST and one side that says Vaccum, people say i need the vaccum part hooked up when i use a boost controller
Old May 19, 2004 | 09:02 PM
liquidxEG's Avatar
you only need to use that other port if you are running an electronic boost controller. just the boost line will be fine if you are letting the spring decide or are using a manual boost controller
Old May 19, 2004 | 10:57 PM
Default Re: vaccum source for wastegate? (liquidxEG)
i got an electronic boost controller the AVC-R gen 2
Old May 19, 2004 | 11:36 PM
liquidxEG's Avatar
oh whoops...in that case what WG are you using? i'm assuming a TiAL...Top port goes to your AVC-R silenoid (sp?) and the side port goes to your compressor housing, or any other vac source (brake booster, FPR, etc.)
Old May 20, 2004 | 12:14 AM
Stu's Avatar
Stu
New User
Don't hook it up to your turbo. It's better to hook it up as close to the intake manifold as possible; at the very least after the intercooler.
Old May 20, 2004 | 04:02 AM
queez's Avatar
Default Re: (Stu)
whats wrong with hooking it up to the turbo?
Old May 20, 2004 | 04:19 AM
FwdCivicHatch's Avatar
Default Re: (queez)
it might see boost pressure a little less than what it will see closer to the manifold, but people don't realize that with a MBC, you can just adjust it to compensate for the difference in boost readings........
Old May 20, 2004 | 04:26 AM
patdemps's Avatar
Default Re: vaccum source for wastegate? (mademan2723)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mademan2723 &raquo;</TD></TR><TR><TD CLASS="quote">T into the brake booster line which is the huge vacum line coming out from the drivers side firewall into the IM.</TD></TR></TABLE>
just what I did. use the side port, not the top one.
Old May 20, 2004 | 04:43 AM
swlabhot's Avatar
Hook the side port of the WG to the intake mani and if you are using an EBC, hook the top port to the EBC.
2ndchirp
May 24, 2009 08:14 PM
Silva Bullit DC4
Jan 17, 2008 02:06 PM
GOIN V8 HUNTIN
Dec 10, 2006 10:51 AM
99silverbullet
Jan 3, 2004 06:28 PM
redhatchb18
Oct 7, 2003 02:26 PM
