Whats the biggest compressor wheel you can fit in the E housing?
Old Nov 7, 2004 | 07:11 PM
*Boostwerks*'s Avatar
Default Whats the biggest compressor wheel you can fit in the E housing?
Is the SC61 the biggest it gets?
I don't have any more room for an S housing, so I'm just wondering what is possible if I even decide to bigger one day.
TIA,
Bryson
Old Nov 7, 2004 | 07:21 PM
SpoolnG2's Avatar
Default Re: Whats the biggest compressor wheel you can fit in the E housing? (Bryson)
what are your goals for the turbo? and whats the rest of your setup?
Old Nov 7, 2004 | 07:27 PM
well...I'm hoping to get into the mid 10s next season.
Setup:
2.0L GSR
T4/SC61
1000cc MSDs
Hondata
and a lot more...
I should be able to make about 550 on this setup if not more, but If I need more down the road I wanna know what my options are.
Right now I have about 2 inches of clearance between the turbo and the JimFab.
Old Nov 7, 2004 | 07:37 PM
TheShodan's Avatar
Moderator
You can go SC63 big shaft in it, but there are tons of other combinations
Old Nov 8, 2004 | 12:09 PM
Like what?
bump.
Old Nov 8, 2004 | 07:17 PM
SpoolnG2's Avatar
Default Re: (Bryson)
how much does your car weigh with you in it? cause 550whp is enough to do 10s for sure. have you actually dyno'd 550whp or is that just what u want? In my heavy *** 2nd gen...on 12.5psi i made 320whp and ran a 12.00. this is on a b16 with a t3/sc61
with a ****** 2.0l b18 and a t4/sc61 you should have no problems at all.
whats your c/r ?
Old Nov 8, 2004 | 07:55 PM
Justin Olson's Avatar
Default Re: (SpoolnG2)
The SC61 can do 600+whp, C16 and 32+psi and you wont need a bigger turbo.
Old Nov 8, 2004 | 08:16 PM
The car weighs about 2300 with me in it. (its one porky little CRX...haha).
I havn't dyno'd the car yet (lack of funds or time), but it should easily do 500. I ran 108mph on 9psi untuned with 19degrees of timing. Based on that 500 should be pretty easy.
And with Hondata I can only run 28psi.
I guess I could always upgrade the engine management instead...
Old Nov 8, 2004 | 08:21 PM
SpoolnG2's Avatar
i wouldnt stress it to much. with a 2300 lb car with u in it especially. if i would have dropped 300lbs off my car i'd be running like 11.60s probably, and this is only on 12.5 psi. Hondata can run approx. 2 bar which is 29.4 psi....thats more then enought for that turbo/motor to make 500+ whp. Once you make that much power in a 2300lb car your not gonna have to worry about a bigger turbo...but worry about how the hell your gonna hook up. Just tune that bitch and get some good seat time and i promise you'll hit mid 10s
Old Nov 8, 2004 | 08:26 PM
Thats what I needed to hear...haha.
I just can't wait for next season. I have ants in my pants by all means.
Old Nov 8, 2004 | 09:10 PM
SpoolnG2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">
I hear that...i'm just gutting my car so i can get a cage put in and then tune this bitch on high boost. 10s here i come too
wfocrx
Mar 3, 2015 12:28 PM
doc
Dec 14, 2005 11:28 PM
stizzit
Sep 6, 2004 07:20 PM
Chubs
Mar 23, 2004 08:37 PM
01ITR#700
Jul 31, 2003 11:03 AM
