Indentify this turbo please, all measurements taken....
My brother bought this a few years ago and I'm not exactly sure if he knew what he was buying at the time. Its a Garrett t3/t4 with a 0.60ar compressor and 0.82ar turbine and thats about all i know.
Compressor side:
ID Tag has P/N: 466159-5004
Housing stamped 0.60 A/R
Small Wheel Diameter ~2.3"
Large Wheel Diameter ~2.95"
6 blades
Turbine Side
Housing stamped 0.82 A/R
Small Wheel Diameter 2.2"
Large Wheel Diameter 2.53"
11 blades
I hope this is everything we need to determine what it is. I know the housing sizes, I would like to know what trim / stage wheel it has and what this turbo is close to that is more popularly known like a sc61, etc.
thanks guys
Modified by stizzit at 3:42 PM 9/6/2004
Compressor side:
6 blades
Turbine Side
11 blades
thanks guys
Re: Indentify this turbo please, all measurements taken.... (stizzit)
Well, it's .82 a/r stage 3 T3 on the exhaust side. Need compressor wheel diameters to determine the rest. Some kind of T4.
Re: Indentify this turbo please, all measurements taken.... (DSF)
Thanks!
I updated the compressor info above and added two pictures. Those should help you to determine the rest.
thanks again
thanks again
I just found out...
compressor trim = (inducer x inducer) / (exducer x exducer) x 100
therefore my compressor trim = ~61
Bottom line
Garrett T3/T4 with a 0.60a/r 0.61trim compressor and a 0.82a/r turbine with a 0.76 trim (isn't that a stage 5)
sound correct?
Now what is this turbo close to, an sc61? a T60-1?
Basically I'm trying to determine if this is the correct turbo for my setup, what it's maximum CFM is going to be and Maximum HP.
Thx guys
Modified by stizzit at 4:11 PM 9/6/2004
Modified by stizzit at 4:56 PM 9/6/2004
Bottom line
sound correct?
Thx guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stizzit »</TD></TR><TR><TD CLASS="quote">Garrett T3/T4 with a 0.60a/r 0.61trim compressor and a 0.82a/r turbine with a 0.76 trim (isn't that a stage 5)
sound correct?
T3/T04E stage 3 turbine in a .82 housing/60 trim compressor
Compressor maps and whatnot found below...
http://64.225.76.178/main.htm
sound correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSF »</TD></TR><TR><TD CLASS="quote">
T3/T04E stage 3 turbine.</TD></TR></TABLE>
DittO
DittO
