HELP: CAR RUNING LEAN WITH TURBO
i need help i have a 94 civic ex with a greddy turbo kit on it and the check engine came on and it was an always run lean code so i bought some 310cc injector and run it with an safc controller my setting are:
crossover
30 60
low throttle high throttle
1k-35 1k-34
2k-4k-34 2k-27
5k-27 3k-27
4k-8k-19
i don't know how to set the safc and can anyone help?
Modified by 94_civicEx at 7:42 PM 10/19/2004
Modified by 94_civicEx at 7:43 PM 10/19/2004
crossover
30 60
1k-35 1k-34
2k-4k-34 2k-27
5k-27 3k-27
4k-8k-19
are those negative values ? with 310's i dont even think you should be leaning them out too much except for idle and low speed driving. this isnt the afc hack.
ya those are negative values and no it not hack and what is hack i'm new to this?
i have no idea how to tune the safc any help will do
and why 450cc injectors
well do you have the blue box a missing link or what? if not you are throwing a code because the ecu is seeing boost. 450s and set the settings to about -35-40 across the board, that is the baseline around here. I don't run it anymore but I have mine at around -30, and it ran just fine.
anothaRRR
Nov 19, 2003 05:33 AM
