Problem, please help. Boosted R, dsm 450, afc hack
Old Nov 12, 2003 | 01:35 PM
anothaRRR's Avatar
Default Problem, please help. Boosted R, dsm 450, afc hack
Please guys I need help, I searched already and cant really find anything that helps. Ok here is the deal, I have a 2000 ITR with a t3/t4b turbo and a apexi safc, the turbo has been on the car for over a month and it was running fine on stock injectors with 4 psi of boost. Well just last week I bought some DSM 450cc injectors and put them on. I trimmed the fuel on the safc and I know the resistor box is hooked up the right way. So basically all I did was change the injectors, hook the resistor box, and trimmed the fuel down to -35 and set th points to 98-99 since all settings are the same.
Ok so I checked the check engine code. P0107 I beleive, which is MAP or Baro sensor low input, wtf is that.
Problem: It idles fine and runs alright until it gets to 5500 rpm-6000rpm. When it gets to that rpm it bogs down and starts to sputter. I took the plugs out and they look fouled out, real black. I was running Denso Iridium plugs. Also when I go to set the sensors and try to get on the flap sensor the car right away idles like **** or sometimes even shutting off. I have all the sensors set at 6 in 6 out.
I would really appreciate the help guys. Thanx alot.
Modified by anothaRRR at 9:39 PM 11/13/2003
Old Nov 12, 2003 | 01:43 PM
anothaRRR's Avatar
Default Re: Problem, please help. Boosted R, dsm 450, afc hack (jz)
pressure is set at 6 in 6 out, what about the other two sensors?? I have them set at 6 in 6 out also.
Old Nov 12, 2003 | 01:45 PM
DRAGLS's Avatar
Default Re: Problem, please help. Boosted R, dsm 450, afc hack (anothaRRR)
are u running an fmu
Old Nov 12, 2003 | 02:17 PM
drvfast's Avatar
seems like your running to rich what are your setting 5500-8000?
Old Nov 12, 2003 | 03:04 PM
PM-Performance's Avatar
Default Re: Problem, please help. Boosted R, dsm 450, afc hack (drvfast)
yea man you cant just guess with fuel. get it on a wideband, im guessing richness
Old Nov 12, 2003 | 03:10 PM
anothaRRR's Avatar
Default Re: Problem, please help. Boosted R, dsm 450, afc hack (itr206)
No fmu, stock fuel pressure regulator. Settings are like at -34 from 5k-7k and on 8k I have it set at -32. From what I have read is that most everybody sets the settings like at -35. All I want is to get the car driveable and then get tuned.
Old Nov 12, 2003 | 03:16 PM
anothaRRR's Avatar
It is reading vacuum properly. So all three sensors are supposed to be set at 6 in 6 out, right?? Also what would cause the car to cut off when I want to adjust the flap sensor. Thanx alot guys I really appreciate it.
Old Nov 12, 2003 | 03:31 PM
Johnyquest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anothaRRR &raquo;</TD></TR><TR><TD CLASS="quote">Also when I go to set the sensors and try to get on the flap sensor the car right away idles like **** or sometimes even shutting off. I have all the sensors set at 6 in 6 out.
I would really appreciate the help guys. Thanx alot. </TD></TR></TABLE>
You don't have a FLAP sensor. You have a MAP sensor.... that might help some....
Old Nov 12, 2003 | 04:43 PM
anothaRRR's Avatar
Default Re: Problem, please help. Boosted R, dsm 450, afc hack (Johnyquest)
Well thats what it refers to on the SAFC, so are they all supposed on 6 in 6 out??
Old Nov 12, 2003 | 06:11 PM
VTC_CiViC's Avatar
Have you tried closing the gap on your plugs? You could very well be blowing out the spark in boost. Close to gap to .028/.030 and try it again.
Old Nov 12, 2003 | 06:19 PM
anothaRRR's Avatar
Default Re: Problem, please help. Boosted R, dsm 450, afc hack (VTC_CiViC)
Yeah I bought new plugs and gapped them like 32. Thats exactly what my car does, it sputters really bad under heavy throttle, I noticed that below 20% throttle it doesnt really do it. I also trimmed the fuel down to like -38 all the way. Its still running like shiet.
Old Nov 13, 2003 | 08:10 AM
anothaRRR's Avatar
Check engine light came on and I checked it. MAP sensor low input&lt;&lt;~~ wtf can I check to figure out the problem
Old Nov 13, 2003 | 10:55 AM
anothaRRR's Avatar
need hlp, plz.
Old Nov 13, 2003 | 12:03 PM
anothaRRR's Avatar
Map or Baro sensor low input &lt;&lt;~~~ wtf is that
Old Nov 13, 2003 | 12:50 PM
swlabhot's Avatar
Sounds like ur ecu is reading boost that its not supposed to (as u've trimmed the fuel already) and it doesn't like it. I would double check the wiring on the AFC to make sure its 100%. Oh and I hope u soldered the wires and not just tapped them into the ECU
Good luck!
Old Nov 13, 2003 | 06:03 PM
Johnyquest's Avatar
Default Re: Problem, please help. Boosted R, dsm 450, afc hack (swlabhot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Well thats what it refers to on the SAFC, so are they all supposed on 6 in 6 out??</TD></TR></TABLE>
did you set the sensor to MAP and leave it alone? When your going through that menu, you are NOT setting different in/out's for all the sensors, you are SELECTING THE TYPE OF SENSOR YOUR CAR HAS!!!!
It nees to be set to MAP!!!!!!!!!
Old Nov 14, 2003 | 12:39 PM
TurboR1391's Avatar
Not to knock what you are doing or come off as a smart ***, but I would put the stock injectors back in and run it with a FMU until you can get it tuned. You really don't need large injectors with the amount of boost you are running. Do you plan on getting a standalone soon? If not what is the most boost you plan on running with stock internals and the VAFC? I would guess no more than 7 or 8 psi. Do you have upgraded internals? When I first had my turbo installed it had the same symptoms your car is having until I put it on a dyno with a wideband. Just trying to help.
Old Nov 19, 2003 | 05:33 AM
COLORPROS's Avatar
Default Re: Problem, please help. Boosted R, dsm 450, afc hack (TurboR1391)
Are you running a Map defender or missing link?
hatchbackjdm
Oct 22, 2005 03:46 PM
turboteg2nv
Nov 3, 2004 06:58 PM
ELSpool
May 16, 2003 05:33 AM
TurboJesse
Apr 23, 2003 11:15 AM
freeplay
Oct 20, 2002 09:05 AM
