F22A turbo throwing map code
Old Sep 6, 2004 | 05:07 PM
Pandahatch's Avatar
Default F22A turbo throwing map code
A friend of mine just finished turboing his 91 Accord LX. He's using pretty much a full DSM turbo setup, turbo, SMIC, charge pipes, etc...At first we ran an SAFC hack with an SAFC II and 450cc injectors, leaned out all the way (50%) it was still running EXTREMELY rich. At first when leaned out to 35% it would not throw a MAP code, but it had a really bad throttle response and it would load up. We switched back to stock injectors and set the SAFC back to 0% across the board. Now the problem is when you drive it under heavy throttle or load, it throws a MAP code. The boost is only hitting 6psi also. Today we put in a MBC today and that is working correctly. Any suggestions, I'm an N/A guy and haven't messed with too much turbo stuff. Thanks.
Modified by PandaHatch at 3:08 AM 9/7/2004
Old Sep 6, 2004 | 06:07 PM
Pandahatch's Avatar
BUMP
regal1975
Jun 6, 2014 08:46 AM
drflako27
Jan 6, 2012 07:57 PM
msinsky14
Nov 4, 2008 04:15 PM
budnick
Jul 28, 2004 09:52 PM
