''simply BLACK''
Old Nov 4, 2017 | 03:34 PM
  #276
ls joker's Avatar
Loved
Default Re: ''simply BLACK''
Got all the hot stuff and turbo taken off. Ready for coating
i thought this was pretty interesting. Never actually looked inside the turbine housing. How much of a pain would it be to port these.
pic of the outside of the block post
Down to the very last thing. And the nut rounds off in the worst spot ever.
Old Nov 5, 2017 | 08:14 AM
  #277
Autoworks's Avatar
I would not suggest trying to port that channel in the turbine housing
Old Nov 5, 2017 | 11:26 AM
  #278
ls joker's Avatar
Loved
oh hell no. I didnt mean myself porting it. Shouldve been more clear. I was tthinkin bout the process of having it professionally ported. And how dragstically would it change the turbos effiency. Or if its just a situation when this should established in the cast before mold.
Old Nov 5, 2017 | 03:33 PM
  #279
TheShodan's Avatar
Moderator
Porting the volute won't really help you. Only possibly the turbine inlet. I suggest making sure it's the correctly sized turbine volute to the exhaust wheel.
Old Nov 6, 2017 | 01:16 PM
  #280
ls joker's Avatar
Loved
Yeeeeaaaa,..... doesnt sounds worth it lol.
Ceramic coated parts will be back friday.
Old Nov 6, 2017 | 07:52 PM
  #281
ErosIsHated's Avatar
Looks good! great numbers.
Old Nov 10, 2017 | 01:35 PM
  #282
ls joker's Avatar
Loved
thanks man. Representin the short 1.6
i hate my life lol. All the hard work to be offset by the chra
Did some grillin outside in 12 degree weather also
Old Nov 13, 2017 | 01:34 PM
  #283
ls joker's Avatar
Loved
Woot, all set. Just gota put my DEI turbo blanket on once it shows up.
Old Nov 14, 2017 | 06:01 AM
  #284
Autoworks's Avatar
coating looks great
Old Jan 18, 2018 | 08:42 AM
  #285
jay2415's Avatar
Great build thread
Old Jan 28, 2018 | 10:42 AM
  #286
Fatalpigs's Avatar
Awesome build the car looks great. Looking to build one myself and also keep track!
Old Jan 28, 2018 | 02:09 PM
  #287
ls joker's Avatar
Loved
Thanks guys. Now that its finally starting to warm up, i get back to the general maintenance.
Old Mar 23, 2018 | 12:37 PM
  #288
ls joker's Avatar
Loved
its that time of year again. Starting to get alittle warmer here. Finally broke down and changed the fluids. First thoughts of the synchrotech/torco mtf was, um.... its ******* yellow. Immediately thought of honda mtf lol. Klotz is red, so thats why it stood out. Thats what i typically run. Didnt seem overly thick while filling. First drive was smooth, no notchiness, grinds, or popout. Better first drive impressions than that redline i had to get last year. Nailed 3rd and 4th a few times, and the shifts were pretty solid. No nonsense. Shifting almost felt light or effortless, like there was no resistance.
after a few heated pulls, i finally started getting the tires to hook today. Took about an hour to get the tires decent so i could get a good feel of 24psi. Whole time driving im thinkin man this feels way slower than last year. Knowing my tires are spinning. However i didnt think they were spinning that bad.
black beast finally showed up though.
got some cleaning and minor stuff to do. Then ill post some videos up. Its annoying how many dumbass driver try to edge you on to nailing it. So im sure there be some interesting vids.
Old Mar 23, 2018 | 09:10 PM
  #289
Pepe14's Avatar
5 Year Member
Loved
Community Favorite
the nuts on the manifold should be replaced when the manifold comes off. Is this your first build?
Old Mar 25, 2018 | 07:34 AM
  #290
Autoworks's Avatar
Good to know. Swapping trans flud is also on my things to do list. Made the mistake of filling my S2k w/ Royal Purple last time (coming from synchromesh)...
Old Mar 25, 2018 | 12:56 PM
  #291
ls joker's Avatar
Loved
Man, both of those names brings up memories of before i was boosted. Way back on one of my jdm b16a swapped cars, with a jdm clutch type lsd tranny. Originally put in royal purple cause of the so called high friction modifier. Right away, on turns, the amount of chatter was insane. Changed that fluid out for pennzoil synchromesh. Instant relief. Still had clutch type lsd chatter. But, was no near as bad on the royal purple. For stock or lower hp/tq setups, id still run pennzoil synchromesh over honda mtf. Ever since they changed their mtf formula.
for what its worth though, drove the si again today. And same as friday, still happy with the torco mtf. Good alternative for klotz that i run. Klotz is just convenient cause it can be locally picked up.
Old Jun 24, 2018 | 07:52 AM
  #292
ls joker's Avatar
Loved
Did some datalogging yesterday. Last summer i upgraded the wiring to the fuel pump using a relay and 10awg ran from my positive distribution block. Havent had the opportunity to make vids and datalog much this year. Anyway last year when i did a quick dyno day when i hit 496whp, my injector duty cycle was 96-97%. Below is a datalog after the fuel pump wiring upgraded. Not sure if it matters or not, but on this datalog run, there was three 220lbs guy in the car.
Old Jun 24, 2018 | 04:35 PM
  #293
boosted94gsr's Avatar
Looks good man. Your car makes good power for being on straight 93 pump gas. What injectors are you running again?
Old Jun 25, 2018 | 01:39 AM
  #294
Balor_Gr's Avatar
Ao 3-4% lower duty from a wire change or am i missing something?
Old Jun 25, 2018 | 05:12 AM
  #295
ls joker's Avatar
Loved
I have nearly ten year old id1000s. Yea i honestly didnt know how big of difference to expect from grading the oem wiring to 10awg with a relay. So i guess the 3-4% isnt bad. Considering it was at 96-97% duty cycle last year. That wouldve been one bad tank of gas or one lean moment when i run out fuel, then the engine popped. Fuel pump wiring should be done around the 500whp anyway. I just didnt think i was up there. Hit 422whp on pure tunings mustang dyno, then 496whp gearmasters dynojet couple months later. In hotter weather also.
Old Jun 27, 2018 | 12:39 AM
  #296
1HGEJ2's Avatar
do u use a fuel pressure regulator that manage 1:1 fuel pressure to boost?
Old Jun 27, 2018 | 10:47 AM
  #297
ls joker's Avatar
Loved
AEM fpr (cant remember which orfice is install), base pressure of 45 i believe lol. I read couple yeara ago, about the adjustable fpr loosing their pressure after years of hot heat cycles. Was gona reorder while ago, since that has also been on the car for nearly ten years. Just as a precautionary measure.
Old Aug 1, 2018 | 07:09 AM
  #298
thjfamily's Avatar
I love the build!
Old Aug 2, 2018 | 05:08 AM
  #299
ls joker's Avatar
Loved
Originally Posted by thjfamily
I love the build!
Thanks man.
hopefully soon my wireworx harness shows up. Thats the likely the last thing this year for black. And had to order the honda steering rack tool for my torque steer. ***** starting to become unbearable. Like a wreckless 16 year old girl.
Old Aug 25, 2018 | 05:08 PM
  #300
ls joker's Avatar
Loved
Update.....
finally got around to adjusting the steering rack. First, i tightened the bolt too much. I did two quarter turns. The car felt like manual rack with a dying power steering pump. Couple days later, i got back under and loosen it a quarter of a turn. Now the car feels responsive as it did prior. But, still kind of loose. So im thinkin, im goin to get back under there, and just bump it a smidge. Heres the steering rack adjustment bolt
i also think the high speed swaying was from a worn sway bar bracket bushing on the front. So those are goin to get replaced with energy suspension bushing and new endlinks. In the front and rear.
now on to the good stuff. Received my wireworx harness today. As advertised, its a thing of beauty. The 18 year old oem harness is starting to get brittle. Had couple wires break at the plug, behind the pin. So it was time.
its a stage 1 with integrated hondata cop harness, id1000s plugs, and extended iat plug. They actually exceeded my expectations on the iat plug. It was ran to the oem location. But they simplified it by making an plug and play harness to reach the sensor in the charge piping. So far i am highly impressed and happy with its presentation. Everything is labeled as an option. Which also makes it easier. Theres a few wire that need to be wired in. In this case i will likely cut off the one obd2b plug off of my old conversion harness. Then solder the few wires to that plug. Then just plug it rite into the oem obd2 secondary harness. Instead of cutting and splicing. I also need to repin my wire for my BBG signal. Only thing that im not fond of is down by the ecu, the wires are zip tied. Im worried in the long run, those zip ties will damage the insulation. Possibly wires. So anyway, onto the pics. I do more during the installation. And how it looks when ran.
