question about ls/vtec...
Old 06-18-2002, 07:39 AM
not so civic's Avatar
Location: gravity rides everything...everything will fall, se GA/ne FL
Default question about ls/vtec...
i read that you get "leakage"? i am considering building one...the only area that i can see that might leak is between the head and block because the gasket holes and openings don't seem to line up right. can anyone who knows, let me know about this leakage if there is and how bad it is? thanks.
Old 06-18-2002, 07:53 AM
X2BOARD's Avatar
Default Re: question about ls/vtec... (not so civic)
There is no 'leakage' unless you screw something up. Doing an LSVT requires you plug an oil galley on the VTEc head since the LS block does not have the oil passages to supply the head (dowels are also modified). This is why you need to run an external oil line from the block to the head.
Done properly, an LSVT does not leak and if a shop tells you this... don't do it with them.
Old 06-18-2002, 10:34 AM
Default Re: question about ls/vtec... (X2BOARD)
no shop ever touches my car or motor...i'll be building it. i was just curious because in a honda tuning or one magazine said "you'll have leakage". maybe it was super street and they suck. i didn't see how though and wondered why they stated that. but i know what's all involved with a proper lsvtec build. thanks for the input.
Old 06-18-2002, 02:14 PM
Eyewitness's Avatar
<------Will NEVER believe what he reads in magazines
Old 06-18-2002, 03:02 PM
sleeper4dr's Avatar
i completely agree. i just finished putting together my second ls/vtec motor this weekend and there are NO leaks. none at all.
thugsbryan
Engine Machining & Assembly
09-17-2015 05:00 PM
Mr.DC2TurBo
02-16-2005 12:57 PM
B16Civic93
12-27-2004 04:20 AM
pulgaleakimports
09-14-2004 02:06 PM
HybriDNA
11-12-2003 10:35 AM
Quick Reply: question about ls/vtec...
