WTF ls/vtec oil leak?
Old Nov 10, 2003 | 08:06 PM
HybriDNA's Avatar
Default WTF ls/vtec oil leak?
Ok well i just put my ls/vtec together. I have a GSR head and B18a1 block. I had the head tapped and dowl pins relocated. Well when i mounted the head to block to torque them down i dipped the headbolts in oil before i torqued them on. After i put every gasket, bolt etc..on about an hour later i see oil between the head and block right underneath where the vtec solenoid is located. I clean the spot every hour and will see a little bit of oil coming down the side of the block... So i need to know why its coming out.. i am using a LS headgasket too. Can someone help me?
Modified by HybriDNA at 6:41 AM 11/11/2003
Old Nov 10, 2003 | 11:04 PM
civicrtype's Avatar
Default Re: WTF ls/vtec oil leak? (HybriDNA)
for an ls/vtec setup u should be using an LS head gasket not a GSR
Old Nov 11, 2003 | 02:41 AM
HybriDNA's Avatar
Default Re: WTF ls/vtec oil leak? (civicrtype)
my bad im using a LS headgasket. not a GSR.. typo.. BUMP!
Old Nov 11, 2003 | 08:10 AM
torr's Avatar
check cam seal and what dizzy are you using, if you used a nonvtec dizzy then you had to cut one of the legs off of it. my buddy cut a leg off his diz and oil leaked a little bit like yours.
Old Nov 11, 2003 | 11:25 AM
AGGRESSIVEDA9's Avatar
Default Re: WTF ls/vtec oil leak? (torr)
**** IM GETTIN THE SAME THING I CHECKED EVERY THING CAM SEAL DIST. ORING I SEEMS 2 BE SEEPING BY THE HEAD GASKET IT SUCKS IM GONNA PUT MY CAMS IN THIS WEEKEND IMA RUNING ARP HEAD STUDS IMA TRY 2 RETORUQE EVERYTHING HOPFULLY THAT WOULD DO IT ILL LET U KNOW WHA HAPPENED
Old Nov 11, 2003 | 12:01 PM
chad's Avatar
Moderator
why does it surprise everyone that there is an oil leak with an ls/vtec, this is not honda reliability built at factory.....
if you don't know how to do it which seems to be the case since you can't troubleshoot an oil leak then why did you do the work yourself?
Old Nov 11, 2003 | 03:11 PM
HybriDNA's Avatar
Default Re: WTF ls/vtec oil leak? (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">why does it surprise everyone that there is an oil leak with an ls/vtec, this is not honda reliability built at factory.....
I guess to learn of your mistakes...
But im using a GSR distributer. Could it be that relocated the dowel pins on the block and not the head?
Old Nov 11, 2003 | 04:15 PM
Benny Hinn's Avatar
if the head was milled/block decked/ or dowel pin holes not drilled down far enough, the dowel pins may not let the head completely seal. If you do remove the head again, grind your dowel pins down a bit shorter than they are now.
Old Nov 11, 2003 | 04:56 PM
chad's Avatar
Moderator
Default Re: WTF ls/vtec oil leak? (Benny Hinn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Benny Hinn &raquo;</TD></TR><TR><TD CLASS="quote">if the head was milled/block decked/ or dowel pin holes not drilled down far enough, the dowel pins may not let the head completely seal. If you do remove the head again, grind your dowel pins down a bit shorter than they are now.</TD></TR></TABLE>
take 1/4 inch off the the pins just to make sure!!! often when a head and block have been milled and decked people forget to make adjustments on the pins....
it could also be from your dizzy or the cam cap in front of the dizzy or the vtec cyliniod leaking....
try those before you rip the head off....maybe the vtec oil pressure switch isn't tight...or the vtec gasket got pinched....
Old Nov 11, 2003 | 07:50 PM
HybriDNA's Avatar
Whoaaa.. this is really wierd i was just driving from work thinking about if the dowel pins where low enough... Well i did have the head milled and the block deck so there is my problem.. BINGO! I sealed my vtec soleniod and cam seal with gasket maker and still have leakage.. so tomorrow im going to shave off the dowels.. THANKS GUYS!
Old Nov 12, 2003 | 06:10 AM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybriDNA &raquo;</TD></TR><TR><TD CLASS="quote">Whoaaa.. this is really wierd i was just driving from work thinking about if the dowel pins where low enough... Well i did have the head milled and the block deck so there is my problem.. BINGO! I sealed my vtec soleniod and cam seal with gasket maker and still have leakage.. so tomorrow im going to shave off the dowels.. THANKS GUYS!</TD></TR></TABLE>
it is NOT absolutely the dowel pins....that is something to check....if vtec and cam cap are still leaking i bet that is the problem!!!
Old Nov 12, 2003 | 07:48 AM
HybriDNA's Avatar
I know its somthing to check by i am so sure it is.. I have used gasket maker for cam caps and solenoid.. I don't even see an oil trailing to the where its leaking... It right between the head and block on the corner of the block..
Old Nov 12, 2003 | 08:13 AM
slixxracing's Avatar
Torr..thats the best quote yet..ROFLMAO
[QUOTE=torr]I wish I can install hondata on my girlfriend so I can tune her mouth shutQUOTE]
Old Nov 12, 2003 | 10:26 AM
torr's Avatar
Default Re: WTF ls/vtec oil leak? (slixxracing)
thanks man
Old Nov 12, 2003 | 10:35 AM
HybriDNA's Avatar
I put the LS headgasket reverse so the little copper o-rings that hold all three layers weren't on the out side so the head didn't seal all the way (i can't believe i did that) aslo i cut the dowel pins about 1/4.. Everything is perfect now. thanks for all your help guys!
Dunc
Aug 2, 2007 08:18 PM
Mr.DC2TurBo
Feb 16, 2005 12:57 PM
pulgaleakimports
Sep 14, 2004 02:06 PM
iblewmyrmotor
Jan 16, 2003 11:32 AM
