Obd2 to Obd1 conversion HELP! Q's
Old 01-10-2004, 03:13 PM
b17a1teg's Avatar
Default Obd2 to Obd1 conversion HELP! Q's
Installing a obd1 vtec f22 sohc into a 97 accord obd2.........
1)do the injectors need to be changed to obd1 or can i still use the obd2 injectors and resistor pack?
2) how to wire up the crank angle sensor....the old motor had the sensor on the block and the new motor has the sensor in the distributer....does anyone know which wires are which can seem to figure it out
3)also need help wiring the obd1 distributer to the obd2 harness....if anyone has done this please help..kinda stuck
thanks
Chris
topherchris
09-26-2007 07:30 PM
Contender25
08-16-2007 07:14 PM
Steve-
10
05-01-2006 08:13 PM
bigtimlikewhoa
11-12-2005 06:57 PM
ekb16
02-15-2005 06:51 AM
Quick Reply: Obd2 to Obd1 conversion HELP! Q's
