headlights get bright when i let off gas
Old 09-24-2003, 10:05 PM
GRAVEDIGGER's Avatar
Default headlights get bright when i let off gas
dim when i get back on the gas. only does this why vehicle is moving.anyone ?????.grounds are all good and very clean.alt looks brand new and when motor was swapped we used a brand new engine harness.wtf
Old 09-25-2003, 09:47 AM
shauniewalnuts's Avatar
Default Re: headlights get bright when i let off gas (GRAVEDIGGER)
dam, i dont know... does the alt belt slip after a certain rpm?
Old 09-25-2003, 11:01 AM
skunked's Avatar
Default Re: headlights get bright when i let off gas (shaun311)
Are you running a aftermarket ignition?
Old 09-25-2003, 11:09 AM
Default Re: headlights get bright when i let off gas (skunked)
no, car is 96 hatch,2000 b16,i/h/e.new cap,rotor,plugs,fuel filter,alt belt.new engine harness and i soldered all connections. used all oem honda parts to.could the alt belt be to tight???
Old 09-25-2003, 01:35 PM
skunked's Avatar
I don't think it has anything to do with the belt being to tite...maybe too loose but in that case you would hear it. Check the voltage output on the alternator.
Old 09-25-2003, 09:32 PM
Intense3.2's Avatar
Alternator not charging properly perhaps?
Old 09-25-2003, 09:55 PM
Default Re: headlights get bright when i let off gas (Atuned2.2ccord)
noticed it happens when using the clutch and gas. not brakes . does not do it when the motor is cold.it kind of feels like the car is surging forward to.
northemt88
11-21-2008 07:31 AM
vlc92189
10
09-24-2007 08:20 PM
00civicsimobstyle
07-14-2005 04:26 PM
GRAVEDIGGER
22
10-11-2003 11:15 PM
Quick Reply: headlights get bright when i let off gas
