headlights dim when letting off the gas and shiftin?
Old 09-23-2007, 08:52 PM
vlc92189's Avatar
Default headlights dim when letting off the gas and shiftin?
when im shiftin the headlights seem to dim out a little.. and when i give it gas to go faster then get brigther.. any ideas
Old 09-23-2007, 09:07 PM
HT White Ops
Eran's Avatar
Most likely, your alternator is going out. As the load on your engine increases, the alternator spins faster, and thus seems healthy. When you slow down, the load decreases, and the dying alternator slows down, getting weaker.
Take it to Autozone, Schucks/Kragen/Checker, O'Riley's, or Advance and get your alternator tested. It's free and quick.
Old 09-23-2007, 09:15 PM
ek-g6's Avatar
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">Most likely, your alternator is going out. As the load on your engine increases, the alternator spins faster, and thus seems healthy. When you slow down, the load decreases, and the dying alternator slows down, getting weaker.
Take it to Autozone, Schucks/Kragen/Checker, O'Riley's, or Advance and get your alternator tested. It's free and quick.</TD></TR></TABLE>
i second that
Old 09-24-2007, 04:50 AM
crazyguy's Avatar
Default Re: (Eran)
+1
Old 09-24-2007, 06:35 AM
hatchedb20's Avatar
Default Re: (crazyguy)
Yes sir and if you take it to one place to have it tested and the tester says its good, get a second opinion. Trust me.... I would hate for you to have to reinstall your old bad alternator because billy bob does not know how to use the machine.... personal experience. Also if your are using a aftermarket alt. pulley this maybe your culprit also. Had them on my last car and the headlights would dim because the alt. was not spinning as fast at red lights.
Old 09-24-2007, 08:57 AM
dividedas1's Avatar
Default Re: (hatchedb20)
shops test the alternator while its still on the car granted the battery and connections are all good. My guess would be the alternator as well though. My headlights were doing the same exact thing for about a month or so. Then one night my battery light started to come on at higher rpms. Sure as **** it was the alternator.
Old 09-24-2007, 08:58 AM
i ♥ snails
quicksilver1689's Avatar
voltage regulator taking a ****?
Old 09-24-2007, 09:41 AM
stehigs321's Avatar
Default Re: (quicksilver1689)
I remember reading about a wire that could be unpinned when doing a obd2 to obd 1 conversion. cant remember which one though.
Old 09-24-2007, 12:36 PM
vlc92189's Avatar
Default Re: (stehigs321)
the car is obd2.. the motor is obd1 and yes it was converted... can you inform me with more possibly?
Old 09-24-2007, 01:35 PM
hatch96y7's Avatar
Default Re: (vlc92189)
WAIT
i had a similar problem when my car would idle it the lights will lose power .
problem was that my vc gasket was leaking into the sparkplug.
got a new gasket everyhting is oaky
Old 09-24-2007, 08:20 PM
vlc92189's Avatar
Default Re: (hatch96y7)
my cars fine at idle..
dilp112
12
11-07-2007 02:52 PM
slow_rex_will
05-21-2005 01:04 PM
bullet9925
02-28-2004 08:34 PM
loopid
12-28-2003 10:45 PM
reeder321
11-28-2003 12:38 PM
Quick Reply: headlights dim when letting off the gas and shiftin?
