headlights get bright when i let off gas
recently swapped motor. now when iam driving and let off gas, lights get a little brighter. also when iam back on gas they dim. wtf anyone know what causes this. car is still the same year obd .so i dont think its the ecu. could it be to tight of a alternater belt?
Re: (mycivicstoo(s)low)
grounds are all good. alt looks brand new. swap is usdm with about 30000 miles.i also used a brand new harness and cleaned all grounds etc before install. help someone . this sh-t is annoying
Guest
Posts: n/a
Re: (blackhatchy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackhatchy »</TD></TR><TR><TD CLASS="quote">usually when you let off the gas, the lights get dim, and when you step on the gas the lights get brighter.
he obviously put the motor in backwards
Re: (99blackcivicSi)
My 00 dx did this when I put my gsr in, my 97 cx did the same thing when I put my ITR into that.. it's a pretty common occurance with swapped Eks. I'm not quite sure how to remedy it though...
I wouldn't be so quick to say it's the alternator or the grounds as there have been other people that have run into the same problem..
Re: (Fowler)
That is just a starting point to trace the problem you go with the most obvious choice first because 50+% of the time that is what it is.you normally don't touch the auxillary light harness when doing a swap so i might have something to do with the alternatar not charging (fully) not hooking one of the grounds up or having to move a ground and not scraping the paint all the way off of where you put it and therefore not getting a proper ground. just a couple of ideas
just cleaned and sanded connecters for the grounds from valve cover,h-lights-tranney. also made sure all grounds including battery were tight. checked all plugs ,connections to alt etc. belt is tight but i dont think overtight.might just be stuck with this i guess.
Re: (GRAVEDIGGER)
hmm did you check realys or anything under the hood see if anyof them might not be getting full power? or if one of shotty that is all i got might be able to think of something else i will get back to you.
1 Post
Re: headlights get bright when i let off gas (GRAVEDIGGER)
Ive got the same issue after my b18c into my 2k ive just lived with it as none of the posts on this site about it have come up with an answer.
sorry to hijack the thread, but what does it mean when you brake and the headlights and everything else dim? Then when I get to about almost 3k they are normal. I checked grounds...... And nothing dims when I have my heater blowing full blast???
well 12V is what your looking for for power. With a new battery and you say the alt. is fine. I assume you got it checked out right? Everything should be fine. As said by someone earlier make sure your grounded properly.
ej6g
15
07-25-2005 09:26 PM
