vtec and turbo
Old Jun 10, 2004 | 07:53 AM
turbo89civicb18hatch's Avatar
Default vtec and turbo
i have herd that vtec dose not go well with turbo, i know because of the higher compresion stock but that can be changed. i here that u lose power when vtec hits, and that an ls turbo would be alot better that any vtec. i dont realy undrstand how it cant be good.
Old Jun 10, 2004 | 08:32 AM
Buzzbomb's Avatar
Default Re: vtec and turbo (turbo89civicb18hatch)
Look at any boosted vtec dyno graph and you'll see that what you've heard is wrong. The valve overlap isn't great enough to cause negative effects.
Modified by Buzzbomb at 2:34 PM 6/10/2004
Old Jun 10, 2004 | 08:35 AM
RTE117's Avatar
Does fine. GSR cams are great for boost.
Old Jun 10, 2004 | 08:51 AM
g0ldywang's Avatar
Default Re: vtec and turbo (IDriveAHonda)
people that say that tend to say it because they dont have vtec. If you compared 2 cars with the exact same turbo setup but one is a gsr and one is an ls, the gsr is going to make more power.
Old Jun 10, 2004 | 09:19 AM
Rod.'s Avatar
Default Re: vtec and turbo (b16agreddynx)
look at all pro drag racers most of them are vtec turbo. Their is some that do not have vtec. Vtec and turbo is not a bad thing
Old Jun 10, 2004 | 09:30 AM
patdemps's Avatar
Default Re: vtec and turbo (redturbocivic)
As stated above. Look at a LS with the same setup as a GSR and your going to see a VERY noticable difference. The GSR head flows better, vtec x-over can be tuned and the gsr tranny is better. You'll get more power out a GSR with the same amount of boost/turbo setup. However, an LS has lower compression which is much safer and will allow you boost higher. The long geared tranny bites but its dealable. There both great for boost. Even Type R's are turbo'd man, and there cams are even more aggressive and there compression is much higher. Its all about tuning.
The kid that told you a vtec car wouldn't work with turbo and would have less power is a moron.
RSRintegra90
May 11, 2005 08:09 AM
AllMotorRP
Feb 18, 2004 04:04 PM
Slvr_CRX
Aug 25, 2003 02:56 PM
jonle28
Jul 21, 2002 06:50 PM
SpeedMonkeyRacing
Jan 17, 2002 10:56 PM
