B20z into 96 Civic LX--OBD2 ecu ok???
Old 12-16-2002, 08:37 PM
gamby's Avatar
Default B20z into 96 Civic LX--OBD2 ecu ok???
I'm in the early stages of planning my project. It will be a daily driver/beater that might get drag raced once in its lifetime. My focus is on having a quick, low-buck, worry-free daily driver.
That said, I'd love to use an obd2 ecu for emissions-hassle-avoidance and convenience (I don't car to track down and spend the money on OBD1 ecu and conversion harness only to have it fail emissions because of ECU tampering).
Are B20 people having good luck using the stock 5-speed CR-V ecu???
Thanks.
[Modified by gamby, 9:42 PM 12/16/2002]
Old 12-16-2002, 08:47 PM
IM ALL BOB's Avatar
Default Re: B20z into 96 Civic LX--OBD2 ecu ok??? (gamby)
I usually see people use the LS ECU obd-2.. or even a DX ecu if you don't have any other option
Old 12-16-2002, 09:05 PM
gamby's Avatar
Default Re: B20z into 96 Civic LX--OBD2 ecu ok??? (IM ALL BOB)
LS... OK, that's cool--still OBD2, so that's nice.
Thanks.
Old 12-17-2002, 01:50 AM
Hatch13's Avatar
I'm using the LS OBDII P75 ECU on my B20. Works just fine.
Old 12-17-2002, 06:18 PM
gamby's Avatar
Default Re: B20z into 96 Civic LX--OBD2 ecu ok??? (Hatch13)
Here's a n00b question--why not use the CR-V stock ecu??? Less aggressive?
Is this a low buck ecu???
Old 12-17-2002, 09:41 PM
Hatch13's Avatar
The hard part is finding a manual FWD only CR-V ECU. If you can find that then I don't see any reason not to use it but luck finding one.
Old 12-18-2002, 05:58 PM
gamby's Avatar
Ah! Now that makes perfect sense. Thanks
wushubrian
01-25-2007 02:43 PM
its WANG yoO
12-08-2003 07:25 AM
fkncivic
05-26-2003 01:49 PM
deviant1
02-15-2003 04:43 AM
Quick Reply: B20z into 96 Civic LX--OBD2 ecu ok???
