b18c engine wiring harness
Need Help Swap Questions.
Hey I need a wiring harness. I have a b18c that i'm swapping into a 95 civic lx. I have a long block out of a 94 gsr. where is the best place to look for a wiring harness.
Also what axles do I need to use?
Do I use shift linkage out of a civic or integra? (the reason i ask is because my car is an automatic and its going to manual)
Any suggestions on this swap would be greatly appreciated. I'm not up on Honda info. My main car is a turbo nissan 200sx.
Modified by jedi_first_degree at 2:54 AM 8/14/2005
u can use ur civic harness and just modify that and u can use any b series hydro tranny or a cable if u get the cable to hydro conversion. any b series axles will usually work...just make sure the half shaft is the same as the other two.
Re: (ekb16)
I'm basically doin' the same swap only mine's an Automatic B18C (sir-g) into an automatic 95 civic ex. I got 3 plugs comming out of the B18C's tranny that don't go anywhere because the stock civic harness doesn't have plugs for that. I don't know where they go and I tried to start the car and it cranks but it didn't start. Any help would be greatly appreciated. Thanks.
