I am going LS..
Down Since Day 1
- Motor
- Hydrolic Tranny (Y80, S80)
- ECU (P75)
- Axles
- Shift Linkage
- Wiring Harness
- Mounts?
Might want to pick up a new water pump and timing belt while you got the motor out. Plus plugs/wires and fluids.
- ECU (P75)
- Axles
- Shift Linkage
- Wiring Harness
- Mounts?
Re: (1 point 6)
- Motor
- ECU (P75)
- Axles
- Shift Linkage
- Wiring Harness
- Mounts from an SI
That's all I need? Then I am good to go for install..
- ECU (P75)
- Axles
- Shift Linkage
- Wiring Harness
- Mounts from an SI
Re: (JDM CTR EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM CTR EK »</TD></TR><TR><TD CLASS="quote">- Motor
- ECU (P75)
- Axles
- Shift Linkage
- Wiring Harness
- Mounts from an SI
That's all I need? Then I am good to go for install.. </TD></TR></TABLE>
u can use a y21 tranny too
and u only need the si or gsr rear tranny mount. i like the gsr mount better cuz it sits slightly lower.
- ECU (P75)
- Axles
- Shift Linkage
- Wiring Harness
- Mounts from an SI
Re: (JDM CTR EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM CTR EK »</TD></TR><TR><TD CLASS="quote">should I go with an SI Tranny and a GSR Mount?</TD></TR></TABLE>
thats what im using and i got no complaints
Re: (WongFeihung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WongFeihung »</TD></TR><TR><TD CLASS="quote">
you using the si or GsR's?</TD></TR></TABLE>
gsr mount
gsr mount
