00si/LSVTEC wiring into 96 hatch
I thought the 99/00 si harness and ecu would work but i found out they don't, so now can't i modify my dx harness with some of the plugs from the si harness to make it work? I got a 97GSr ecu . So if anyone knows what all i have to splice and extend, let me know i need to get my car running. Thanks
But like HRILSVTEC says, you could use the 00 Si engine harness and use a 99-00 GSR/ITR/B16 ECU.
You can use a Si wiring harness with an Si computer.I was running a Si computer and wiring harness in my 98 EK
You can rewire the OBD2a DX too, such as i did on my friends GSR swap.... It is a little more work to rework the IAC and stuff but it wasn't all that bad.. Good Luck
goforbroke
Apr 5, 2004 09:25 PM
