Need help asap Code 54 Crank Fluctuation Sensor question
Old 06-08-2005, 08:49 AM
scoobyghost's Avatar
Default Need help asap Code 54 Crank Fluctuation Sensor question
My sister is trying to pass emissions but the guy won't pass it because of the check engine light. She's throwing a code 54 crank fluctuation sensor. How can I fix this problem?
Old 07-07-2005, 10:32 AM
96ex's Avatar
Default Re: Need help asap Code 54 Crank Fluctuation Sensor question (scoobyghost)
bump for you cause my 96 civic just started throwing that code. Luckily i got it inspected yesterday!
Old 08-04-2005, 12:47 PM
Help we my pennies
BLUE EH3's Avatar
Default Re: Need help asap Code 54 Crank Fluctuation Sensor question (96ex)
me2
Old 08-07-2005, 02:58 PM
TurboEclipse's Avatar
I just put a B16A2 oil pump onto a B16A motor for the purpose of installing the crank function sensor. The sensor is brand new as is the oil pump and I am still getting the code 54. Any one have any ideas.
Old 08-07-2005, 04:36 PM
Needs to be About 20% Cooler
DieMaster's Avatar
Default Re: (TurboEclipse)
WRONG FOURM PEPOLE
READ PRE-92 CIVICS
Old 08-07-2005, 04:45 PM
b18ccivics's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboEclipse &raquo;</TD></TR><TR><TD CLASS="quote">I just put a B16A2 oil pump onto a B16A motor for the purpose of installing the crank function sensor. The sensor is brand new as is the oil pump and I am still getting the code 54. Any one have any ideas.</TD></TR></TABLE>
did you change the timing belt gear?
Old 08-07-2005, 05:29 PM
Default Re: (b18ccivics)
Hey sorry about the wrong forum, I was just searching and it popped up. No I did not change the timing belt gear. I am now assuming thats where my problem lies as there is nothing for the magnetic sensor to pick up on.
Old 08-07-2005, 08:19 PM
RC000E's Avatar
Crank fluctuation is usually connected to a small cylinder misfire. Something as simple as carbon'd up or old plugs can cause it. The next possibility is problems with the ignitor or dizzy problems in general. Basically check out your ignition system as a whole.
The next possibility is that the crank fluc sensor has a problem in itself. Check your wiring and the sensor itself. Helm's has simple test procedures for the sensor which you can follow in flowchart format.
Keno Smith
11-05-2012 10:56 AM
markovwgti
07-24-2008 11:08 AM
96GS-R-Kaden
05-30-2008 05:02 PM
greentegsandspam
04-30-2005 12:12 AM
mraudio13
09-19-2002 05:34 PM
Quick Reply: Need help asap Code 54 Crank Fluctuation Sensor question
