crx sputtering!!
Old 09-30-2008, 05:01 AM
eghonda1320's Avatar
Default crx sputtering!!
I have a 91 crx hf with a obd0 Jdm b16 swap I was throwing a tps code and I found out my tps was bad so I replaced it and calibrated it to .4 volts. Now when I'm driving at a constant rpm it sputters real bad but when I unplug the tps and drive it it runsgood and doesn't sputter but throw the code and check engine I can't figure it out
Old 10-01-2008, 07:09 AM
no one has any idea what would cause this
Old 10-01-2008, 07:31 AM
IYAAYAS
ammob16's Avatar
Default Re: (eghonda1320)
I've noticed mine doing this as well. Usually at a constant speed in any gear sitting at about 3k rpm.
Old 10-01-2008, 12:25 PM
traxxasx's Avatar
supossed to be .5volts, also make sure the 2 outer wires on the tps plug are switched with each other.
Old 10-01-2008, 06:12 PM
alscrx's Avatar
Default Re: (traxxasx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eghonda1320 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 91 crx hf with a obd0 Jdm b16 swap I was throwing a tps code and I found out my tps was bad so I replaced it and calibrated it to .4 volts. Now when I'm driving at a constant rpm it sputters real bad but when I unplug the tps and drive it it runsgood and doesn't sputter but throw the code and check engine I can't figure it out</TD></TR></TABLE>
Still sounds like the TPS. make sure new one is good.
.45v when plate is closed!
Wide open throttle should be 4.45 or higher
Green=ground(probe with - or black wire on meter)
yellow=5 volt wire
red=throttle position(probe with + or red wire on meter)
Modified by alscrx at 10:21 PM 10/1/2008
Old 10-04-2008, 11:10 AM
thanks I tried that just now the tps is good and the tps reads .45 at idle and 4.6at full throttle but it still sputters when the tps is pluged In. I heard it it might be the fuel to air ratio is off cause my Intake and 2 1/2 in. Exhaust and I might need adjustable fuel regulater?? Idk I've been around hondas for a while and I never heard of anyone with the same problem
Old 10-04-2008, 02:32 PM
this is driving me crazy
Old 10-08-2008, 06:51 AM
Bump no one has a clue??
Old 10-08-2008, 07:38 AM
jaminze's Avatar
Its possibly the fuel to air because mines did the same thing when i had a crack in my power brake booter and i replaced it and the problem went away. and it was throwing a tps code as well. check all the vacuum lines and fuel filter
Old 10-08-2008, 11:06 AM
LUIlui77's Avatar
Default Re: crx sputtering!! (eghonda1320)
Did u find the cause for your dismay? I have an 88 with a b16 dropped in it as well and having a similar problem. Im not sure what it is. The motor sputters driving at low rpms or at minimal throttle(when driving), above 3500 rpm its fine. I was thinking it might b my tps, but not sure. Also thought it would be the lack of O2 hooked up(running open loop). I had the ecu chipped and with that some sensors were eliminated. Now my car is running slightly rich(not bad)but still having he same problem. Could it be something in my suspension or axels?
Old 10-09-2008, 02:50 PM
still didnt find the cause i tried everything just about.all vacumn lines are hooked up correct and tps is brand new and calibrated correctly.im not throwing any codes everything is wired correctly both 02 sensors are where there soposed to be and wired right. idk...
Old 10-09-2008, 03:44 PM
LUIlui77's Avatar
damn, sucks. I would suggest going to a shop. Find a good mechanic that can diagnose the prolem. Its wortless now to take tips(i think). My b16 sputters off/on, but it does no effect the power nor reliability of the motor. I hve been researching like a "mad man" trying to figure this. I decided to have a shop check it out. Erick from ericksracing.com is going to check it out. Im hoping to have a complete -Leak Down and compression test, hopefully in doing so i can my problem. But who knows it could b something with my timing. Let me ask u a question. Does ur car sputter throughout the entire RPM range, or at certain intervals?
Old 10-09-2008, 10:40 PM
flaxx0r's Avatar
mine sputterd when the o2s where hookd up backwards.. just an idea
Old 10-22-2012, 09:52 PM
braass91's Avatar
My stock 91 DX Hatch started sputtering while driving around the city but not on the freeway. Any clues? Thanks
Old 10-22-2012, 10:44 PM
Good, Bad…I'm the one with the gun
Ash J. Williams's Avatar
Location: Trapped in time, Surrounded by evil, Low on gas
broad things of issues could cause that. start with the basics. codes?
Old 10-22-2012, 10:49 PM
braass91's Avatar
No codes, just sputtering.
Old 10-23-2012, 03:23 PM
braass91's Avatar
Does anyone know the what might be causing my stock 1991 Civic Hatchback DX to sputter? Idle is normal, freeway driving is normal, only sputters while starting from a stop, pretty much in all gears except 5th or while driving on the freeway. No CEL code. Thanks
WhosThisGuy
03-01-2014 06:15 AM
UnknownKid
01-13-2011 08:07 PM
wagalude
09-24-2009 11:40 AM
classciv
05-12-2007 01:47 PM
JDM91Bseries
09-05-2006 07:08 AM
Quick Reply: crx sputtering!!
