vtec not working !!
vtec not working !!
i just put in a jdm d15b in my 93 ex coupe and and after the swap was done i took it for a test drive and vtec did not work.. its supposed to engage at 5500 rpm.. and it never did anything.. i have the same p28 ecu.. and with the d16z6 that i had b4 vtec would kick in at 4500 rpm. and i changed to vtec solenoid from the d16 to the d15 and still nothing.. what can it be..??????
Re: vtec not working !! (ej_vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCejcivic »</TD></TR><TR><TD CLASS="quote">yeah...you can't really hear it or feel it.</TD></TR></TABLE>
Maybe you should test the solenoid and make sure that it is working. Also, make sure that your oil pressure/oil level is enough. Also make sure that the car is at N.O.T. since it needs to be in order for vtec to engage.
-Shane
-Shane
well i can help you with this i need to know two different things tho. u put the motor in right there for you have to wire v-tec so where are the v-tec wire connecting into your ecu at. also what pin is the v-tec oil pressure connect at
Re: vtec not working !! (nighttrain33)
You can read many FAQ's here. They are very helpful and can answer many of the questions that you may have. Also, the <FONT COLOR="red">Search</FONT> function is very useful, especially when you archive your search.
You will learn that by searching, you will be posting very few questions, as almost any question you have will probably be answered by searching/the FAQ.
-Shane
-Shane
The JDM D15B vtec engine has a much larger low cam profile then the other sohc vtec engines so when it crosses over to high cam you cant really tell all that much.
lol you did the oppisite as me .. i went from a d15b to a d16z6 and personally i like the d16 better .. you can feel vtec on both .. maybe its your vtec solinoid check that
b16mike
05-13-2005 09:51 PM
