vtec isnt working
Old 06-24-2011, 09:42 PM
volcomej1's Avatar
Default vtec isnt working
so i have a lsvtec but the vtec isnt working anymore and now its alot more sluggish tourqe wise first gear is really slow but it picks up speed then the vtec wont engage its got oil there is no check engine light so i dont thin its the ecu so any ideas?
Old 06-24-2011, 10:23 PM
phoxking's Avatar
Default Re: vtec isnt working
clean your vtec solenoid, or clean spray your ish with brake cleaner to remove the dirt and see if that helps in any way mayb.
Old 06-24-2011, 10:25 PM
HOMEMADEPOWER's Avatar
Maybe your vtec solenoid screen is dirty
Old 06-24-2011, 11:13 PM
phoxking's Avatar
x2 check that first and let us know the results!
Old 06-25-2011, 08:55 AM
Sp00n2nr's Avatar
Definitely clean the sol out and another thing are you running any cel codes? Could be a loose or bad connection too.
Old 06-25-2011, 09:01 AM
h22apwrd95's Avatar
That sounds like more than a vtec solenoid issue if it is down on power throughout the whole rev range. What about timing? Did you check base distributor timing with a timing light? If cleaning the solenoid does not fix all your issues, this would be where I would check next.
Old 06-25-2011, 12:07 PM
Technical Hero
HondaPartsHero's Avatar
https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%22my-vtec-doesnt-work%22-1812135/
swizz977
10
05-25-2011 08:15 PM
PWRDbyHseries
04-07-2008 07:46 PM
DougNuts
01-19-2008 01:16 PM
1ntensiveVTECivic
11-22-2003 10:33 PM
Yellb16crxsi
02-13-2003 01:57 PM
Quick Reply: vtec isnt working
