knock sensor question.
Old Aug 7, 2003 | 05:30 PM
untitled's Avatar
Default knock sensor question.
if i plugg the knock sensor in but dont thread it in the block(pr3 ecu) will any CEL appear. i swapping in my ls.vtec and i plan on getting the hodata chipped without knock sensor later. thanx
Old Aug 8, 2003 | 11:29 AM
untitled's Avatar
Default Re: knock sensor question. (88crx91integra)
its a b18a block so it has no place for a knock sensor. help.
Old Aug 8, 2003 | 03:42 PM
untitled's Avatar
will it? the ecu reads off voltage and the sensor will only send a certain amount of volts if the engine knocks right? so then if the sensor isnt in the block it see any knock and it wont send any voltage to the ecu and the ecu will think that everything is good?
Old Aug 8, 2003 | 03:54 PM
NonovUrbizniz's Avatar
Loved
It should be fine but if that frequency range is produced by anything else it will probobly retard the timing.
Old Aug 8, 2003 | 03:55 PM
mr.beeks's Avatar
here is some info from
http://www.c-speedracing.com
Old Aug 8, 2003 | 08:03 PM
sander's Avatar
2.7(p/t)
Default Re: knock sensor question. (francisco flores)
i did the c-speed reccomendation on mine, and havent had a problem, just take your time with tapping the threads, knock sensors are always good to have in case you infact do knock.
-sander
hondakrazy
Nov 14, 2008 10:42 AM
1.5boosted
Dec 14, 2007 01:45 PM
92ludeport
Jul 8, 2005 02:08 PM
untitled
Jul 9, 2003 04:33 PM
delslow94
Dec 26, 2002 12:52 PM
