theoretical question....(tps set higher)
Old 09-06-2007, 07:10 AM
RACEPAK's Avatar
Default theoretical question....(tps set higher)
sup.
just wondering.
lets say your tps is set higher then what it suppose to....
what will it cause and how.
thanks.
Old 09-06-2007, 07:13 AM
darkclark's Avatar
Default Re: theoretical question....(tps set higher) (RACEPAK)
car will probably run very rich at idle because it thinks it is above idle. it might rev higher at idle and it will probably have poor throttle responce
Old 09-06-2007, 08:22 AM
Relic1's Avatar
to add to what darkclark said
depending on how much off it is...
the RPMs will surge at idle. run rich at all times, and may set a CEL.
reason: the ECU sees certain readings from other sensors (mainly the MAP) and a certain TPS reading, and they don't make sense together.
JasonST
06-30-2006 11:22 AM
daddymaxx
12-15-2003 12:24 PM
asianspeed
02-25-2003 07:19 PM
Quick Reply: theoretical question....(tps set higher)
