sunpro tach question????
hey all i was given a sunpro tach drag n tech or something like that. and i dont have any insructions. their is a red (power) black (ground) white (light) and a green (???) wires. i think i know some of them as i listed above but i have no clue about the green one. someone told me it goes on the ignition coil and someone else told me to splice into a wire that goes to the distributor they did not tell me which wire. i took some picture around the distributor if someone can point out the wire or just tell me which one it is that would be great.
http://fasterbeats.servehttp.c...1.jpg
http://fasterbeats.servehttp.c...4.jpg
http://fasterbeats.servehttp.c...8.jpg
where on the ecu cause i am cluess but i do know how to take an ecu out and put one in. i assume that we would be splicing a wire where the grey connecter plugs in right ???
Re: sunpro tach question???? (fasterthenmost)
I just installed one today I'll reply back from my work tomorrow when i get there. I have the diagrams I can copy and send them to you.
DEF
DEF
Unceasing Measure
Re: sunpro tach question???? (deftones0817)
The "light" wire can go to an ignition-triggered power wire or a dedicated light-triggered wire. The green wire is Tach signal output...it tells the tach what rpm you're at.
that green wire is the rpm signal wire. It needs to be connected to a baby blue wire that is a part of your harness. It runs to a loom on the driver's side of the engine bay over in front of the brake master cylinder. that is where mine is tied in. You can see the blue wire i am speaking of in the picture with the distro. you will see it on that driver's side too.
Here is my link for my write up on HAN where i installed my sunpro super tach II in my Dx:
http://www.honda-acura.net/for...81791
Hope this helps
Hope this helps
Re: (fearthegerbil)
Thanks everyone for all your help I am gonna do it tommorrow and feel confident i will take some pics and combine them with feathegerbil tutorial. fearthegerbil contact me and let me know what pics you want.
ONE LAST PIC TO MAKE SURE I GOT YOU CORRECTLY AND THIS SHOULD HELP EVERYONE OUT!!!!
gee thanks badeg6 your such a nice guy!!! If you aint got nothing good to say don't say it. if there was a noob section i would of posted it there but there isn't one!!!!!!!!!!
Re: (fasterthenmost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fasterthenmost »</TD></TR><TR><TD CLASS="quote">
haha, tap into what? you're showing the whole harness.
Why dont you do it the easy way, and wire it to the RPM testing plug located drivers side where the engine harness plugs into the in-car harness. Its a blue wire, with a plug. Should be taped to the side of the wiring harness.
91CivicHatchback
05-22-2005 03:45 PM
D1ANCER
04-02-2002 11:05 PM
