shift linkage trans seal replacment. help
hi, my trans i leaking out of the oil seal around the shift linkage, first off, i can't find a part number on hondaautomotiveparts.com, all i could find was the dust boot, its a b18c btw. and second is it even replaceable without pulling and disassembling the trans? thanks in advance
Re: shift linkage trans seal replacment. help (littlegreenb18)
Yes you could just pull it out if you have the right tools, for finding the part just go to a Acura dealer ship and they will have a computer that got all the **** and part number for the tranny.
Re: shift linkage trans seal replacment. help (BOOSTED RIVIL)
I've replaced that seal a number of times.
It's pretty easy, just take the boot off, remove the retaining clip and bitch pin, then pull the old seal out with vise grips. That's what I used at least. Then the new seal just slides right in.
It only takes a few minutes. Your Honda/Acura dealer should be able to hook you up with the correct seal, my local dealership always has them in stock.
Randomnoob
02-27-2019 06:34 AM
