Question about a noise in my tranny.....
This has been going on for a while now, when I'm driving the car i get this weird growling/chattering noise coming from the tranny. Sometimes when I start out its not there but around 3-4k rpms it comes back. All the other gears it does it at any rpm, but when I push the clutch in it goes away. It also chatters when I'm just sitting still in neutral.... I have a 97 ex so if anyone could give me and idea what it might be it would be most appreciated.....
Re: Question about a noise in my tranny..... (Pslappa)
Mine does it too, tranny still seems to operate just fine right?
It could be a bad throwout bearing in the clutch, or I am guessing I may have chipped a tooth on a gear or something and its just enough to make some noise.
YUP FOOKLE IS RIGHT IS A BEARING IN THE CLUTCH I HAD THE SAME PROBLEM WHEN I HAF STOCK ENGINE, EVERYTIMES U PRESS THE CLUTCH THE SOUND GO AND WHEN U LET IT GO IT COMES BACK.................... MY MECANIK TOLD ME THAT IS BETTER TO CHANGE THE TRANNY.......IS A BITCH MAN...............LATER
Re: Question about a noise in my tranny..... (fookle)
yes it seems to work just fine, i was looking through ht and found this, is this it?
https://honda-tech.com/zerothread?id=596873
Risky Business
I wrote that writeup. And yes that is the problem you are having. You need a new input shaft bearing (or possibly another bearing on the mainshaft)
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pslappa »</TD></TR><TR><TD CLASS="quote">sweet thanks, one more thing where did you get the bearing and how much was it....</TD></TR></TABLE>
Slhondaparts.com
$30 w/ seal
Slhondaparts.com
$30 w/ seal
JDM SLICK
02-15-2005 11:17 PM
Pinhead
02-04-2002 12:37 PM
