wierd tranny noise
OG triple OG
wierd tranny noise
when i let out my clutch with the tranny in neutral it makes a tiny quiet rattlying noise , is my throwout bearing fuckered? with the clutch in there is no noise
Re: wierd tranny noise (TURSpoonEK)
yeah Im geting the same thing. When I press the clutch it squeeks and the linkage too. rattling while rolling with it pressed in. Chattering while in N when not pressing the clutch.
New clutch or what. 98 civic ex
Re: wierd tranny noise (JALOP B16)
almost what happen to me it was a little whin, with my old transmision it just gave out. but its all better now, cuz im loving the tranny i have now
Re: (quik1)
I also had the same problem with 2 of my trannys. 1st I replaced the t/o bearing and still had the noise and I ended up just changing the tranny.
And I'm about to do it again on another car
the squeek is in the pedal assembly if you just spray it with some penetrating oil or wd40 it'll go away...
as far as the posters problem I'm not exactly clear on where and when the noise is...
Re: wierd tranny noise (NonovUrbizniz)
Its a $40 bearing but alot of work to tear down the tranny and change it. Don't replace the tranny just get it fixed it happens to alot of hondas. They even sell tranny fluid at honda that is supposed to help with that problem.
OG triple OG
Re: wierd tranny noise (quik1)
im using redline mtf , should i switch to the honda stuff???? i dont want to replace the bearing because im swappin the motor soon.
If your swapping the motor I would not worry about it, I have a friend that waited 1.5 years before I changed his.
Its your throw out bearing. My clutch went out just last night. It was mainly the TOB grinding when trying to find the gear. 500.00 to get everything replaced including flywheel resurfaced and rear main seal replaced
JDM SLICK
02-15-2005 11:17 PM
