p28 on d16z6
Old 12-01-2008, 05:22 AM
deemy72's Avatar
Default p28 on d16z6
I got a p28 comp in my 93 coupe and the other day it was having trouble trying to start but after it started it keep back firing and wasn't idling right. so when I was driving it and I was red lining like 5600.
new ecu right? cause I might get a p72 ; will that one give me any problems?
Old 12-01-2008, 05:30 AM
Hanmin's Avatar
if you get a new ecu, get a p28. a p72 will make you run rich and will throw a knock sensor code. its something else, go to a mechanic. maybe your dizzy is fudged up, or you jumped a tooth.
Old 12-01-2008, 06:53 AM
THC07's Avatar
I wouldnt say that ecu was bad. is there a solid light? even when you jump the service connector?
the computers limp mode is 3k not 5600.
If you decide you want a chipped computer, lmk, I offer the best prices.
Old 12-01-2008, 08:23 AM
deemy72's Avatar
idk im new to the honda game but it might be the dizzy idk cause I started it and I was pressing the gas and it wasn't reving or nothing it just keep sputtering then it starts bouncing off idle so ima take it to my boy and see whats wrong?
Old 12-01-2008, 09:04 AM
turbojdmhatch's Avatar
yea take it to your boy and find out
Old 12-01-2008, 09:28 AM
deemy72's Avatar
iight and i got another issue lol like the throttle body cable under my gas pedal is loose for some reason so like when i press the gas it has like a lag to it after i reach a certain point it pulls the cable and then it revs. how do i make that tighter?
Old 12-01-2008, 07:41 PM
deemy72's Avatar
Old 12-01-2008, 09:47 PM
trustdestruction's Avatar
Adjust it at the throttle body.
But first, take the intake off and look in the throttle body and have someone push the gas pedal slowly and gradually (engine off) and have them tell you exactly when they push it. If the butterfly starts to open as soon as then press the pedal, it's not out of adjustment and your problem lies elsewhere.
JDMb18c1HATCH
08-20-2010 07:06 AM
dynimitejack
12-31-2008 09:37 PM
GSR_hatch936
10-02-2007 06:09 PM
Hondasaurs
04-28-2003 01:47 PM
brbHPR
03-13-2003 09:19 PM
Quick Reply: p28 on d16z6
