what the hell goes in here??!!
Old Jan 19, 2010 | 05:02 PM
EG6 Love's Avatar
Default what the hell goes in here??!!
96 b18c1 block... what goes in this threaded hole? ive been triing to figure it out for quite some time (2 weeks)!!
thanks, doug
Old Jan 19, 2010 | 05:28 PM
all-mtr-teg's Avatar
Default Re: what the hell goes in here??!!
On OBD1 blocks that come factory with the oil cooler, a coolant fitting would thread into that hole and a coolant hose would connect from the oil cooler to that coolant fitting. I'd remove that oil cooler, and install a oil filter holder part number 15 below and plug that hole up with a pipe plug, just like a stock 1996 GSR block, since you don't have the proper water pump coolant tube to use the oil cooler anyways.
http://www.hondapartsunlimited.com/i...OIL%20STRAINER
If you do decide to use that oil cooler you'll need part #1 below, which is the coolant fitting, part #2 & 3, the coolant hoses, and
http://www.hondapartsunlimited.com/i...ER%20HOSE%20(3)
and Part # 9 and 16, the coolant tube and o-rings
http://www.hondapartsunlimited.com/i...%20SENSOR%20(2)
Old Jan 19, 2010 | 07:39 PM
EG6 Love's Avatar
perfect answer! thanks.
oranginal
Mar 30, 2009 07:39 AM
welfarepc
Jan 10, 2007 10:26 AM
SkoundrelUSA
Aug 23, 2006 08:42 AM
H23 Accord
Mar 10, 2005 08:11 AM
skunk2finatic
Dec 16, 2004 02:46 PM
