Making sure on b16 mounts for a swap into an ek
Ok, so I'm getting ready to order up some mounts for the swap. From what i understand I'm going to need the rear mount (#7), the timing cover side mount (#4 & #6), and the front tranny mount (#10). I am also wondering if I will be needing any rubber bushings or if I will be needing the compressor bracket (I have no AC). Is there any other parts I will be needing other then the ones I have listed.
PS This picture are the motor mounts off of a 99-00 Civic Si from the majestic honda site.
Re: Making sure on b16 mounts for a swap into an ek (aw1234dude)
Don't run without that a/c mount, it's rather important. Even if you don't have a/c you just use that bracket (#1) and the bolt for it (#11). Your ek has the bushing (#9) on the car. when i did my b16 i didn't have that mount in and it was impossible to drive the car over 3k rpm because the car shook and bounced so much. as for the mount bushings im not sure but if they are torn or you want something stiffer you can order new ones. thats up to you. good luck!
GrimeyAssLos
11
02-27-2012 09:56 AM
SeVeNisOnE
18
05-21-2008 03:02 PM
EKRacer
10
05-06-2004 08:47 AM
