basic ls swap questions
just picked up a 95 hb for cheap-i am getting an ls motor with tranny and shift linkage and ecu? - what else do i need?? does the civic wiring harness work-or do i have to change/modify it like my b16 harness in my 89hb?? any reply's and/or help is always appreciated.
Re: basic ls swap questions (deez92)
what about motor mounts?????can the stock mounts from the ls integra fit because i have been told that i am going to need gsr motor mounts for it to fit. help the confuzed
Re: basic ls swap questions (juicedricer)
GSR and LS mounts are the same.
The easiest way is to use everything from the integra: Axles, ecu, mounts, engine harness, etc.
If you have all of this, the LS swap into a 92-95 civic is completely plug and play.
Very simple swap.
Very simple swap.
Re: basic ls swap questions (Slopoke)
Very simple swap.
Very simple swap.
preetyboi06
07-17-2009 09:57 AM
