where to install autometer oil pressure sending unit?
Old Oct 10, 2008 | 12:59 PM
twentyhurtz's Avatar
Default where to install autometer oil pressure sending unit?
ok i have to tap into oil somewhere, but where is the easiest, what is the most commonly known place to run the line to tap into the oil for a pressure reading? i have seen these oil pressure sandwhich plates that go between block and filter, but not sure about them, any alternatives are appreciated thanks!
Old Oct 10, 2008 | 01:05 PM
LastGenEK's Avatar
Default Re: where to install autometer oil pressure sending unit? (twentyhurtz)
I have my autometer screwed into my T fitting for my turbo off the factory oil sending unit works great!
Old Oct 10, 2008 | 01:12 PM
Default Re: where to install autometer oil pressure sending unit? (LastGenEK)
i'm not boosted yet, not to sound dumb but here goes? my car has a factory oil pressure sending unit? i know it has to have some way to determine low oil pressure, thus the oil light coming on, but i didn't know you could tap in there, so where is it? back of block?
Old Oct 10, 2008 | 01:28 PM
onepoint6i's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twentyhurtz &raquo;</TD></TR><TR><TD CLASS="quote">i'm not boosted yet, not to sound dumb but here goes? my car has a factory oil pressure sending unit? i know it has to have some way to determine low oil pressure, thus the oil light coming on, but i didn't know you could tap in there, so where is it? back of block?</TD></TR></TABLE>
EDIT: yeah its on the back of the block, with this fitting here you screw it in place of the stock sending unit, then screw the stock one on to it and you have two more ports for whatever you need..
https://honda-tech.com/zerothread?id=1902471
i bought that first fitting..works great..it has a total of three outlets for future use if needed
Old Oct 11, 2008 | 10:41 AM
LastGenEK's Avatar
Default Re: where to install autometer oil pressure sending unit? (onepoint6i)
Yeah you Fun A T fitting off the factory sending unit
Ill try to post a pic when i get home!
Old Dec 5, 2008 | 09:22 AM
bad1_s2k's Avatar
I bought the steathmode fitting. But now my sending unit does not fit in it.
PS: sorry for bumping a old thread.. its not really that old anyway
Old Dec 6, 2008 | 11:22 AM
vti444's Avatar
most common is to stick t piece into oem press location in block and stick oem and aftermarket sensor into t piece
other is sandwhich plate between oil block and oil filter and just stick aftermarket sensor into that
or this which im in process of doing right now after reading this endyn article
http://theoldone.com/articles/oilpressure/
Old Dec 7, 2008 | 09:17 AM
reaction360's Avatar
I recommend a sandwich adapter. It has at least 2 ports, so you can run the sender and in the future if you go turbo, you have a spot ready for the oil feed for the turbo. I used to run the T fittings but stopped after one broke on me.
EFsideways
Jan 1, 2008 01:52 PM
preludefien
Apr 18, 2007 06:28 PM
vtec.dc2
Mar 9, 2004 08:18 AM
vtecsiqt
Jun 17, 2002 07:51 PM
