5 lug conversion what is exactly needed?
Old Aug 11, 2003 | 04:30 PM
subzero_SiR's Avatar
Default 5 lug conversion what is exactly needed?
I can get my hands on a conversion from a 01 type R...what is exactly needed?
can I use my stock shocks or do I need itr shocks? I'm getting a good deal with
itr rims for probably around $1500 canadian...thanks all in advance who reply
Old Aug 11, 2003 | 04:39 PM
Mohudsolo's Avatar
Default Re: 5 lug conversion what is exactly needed? (subzero_SiR)
I think you can use the fronts. The backs depend on if you use the lower control arm from your car or the ITR. The ITR uses a fabricated steel arm versus the cast arm from other models. The lower shock mount is totally different. Either will bolt up, but I have heard the camber curve is more aggressive on the ITR arm. That may not be true though, hopefully someone who knows for sure will reply.
philliedawg
Feb 6, 2010 09:17 AM
jdm_ek209
Jan 21, 2007 06:07 AM
fabworxs
Feb 17, 2006 04:17 PM
compwc18
Apr 9, 2005 03:54 AM
.jacob
Aug 19, 2003 10:23 AM
