ignition control module question
ok, so here we go again with more problems and more money needing to be spent.
like you probably all know by all the questions i ask, i swapped my 96 ex with a b16b.
ive ran into nothing but problems lately with the car not starting due to wrong engine harness, then i needed to wait for a ecu jumper, now i have no spark.
using my haynes manual (i realized b16b isnt in it), i did all the tests on my distributor and it stated at the end "if all the voltages meet the requirements, replace your icm".
E12-303 Hitachi 9315 is the number and name on it.
is the 9315 important? because i have a E12-303 Hitachi 6417 from my d16y8 dizzy
is this the problem? if so, where do i find these? do i have to goto honda or would jobbers carry them?
Last edited by laperriere; 05-30-2012 at 08:15 PM. Reason: forgot to ask something
Re: ignition control module question
This may sound stupid but have you checked the ICM fuse under your dash?
You re-wired your EX harness to mate with your B16B motor? So you used the EX OBD2A harness on a OBD2B motor, which isn't a big problem.
The biggest part was re-wiring the dizzy correct?
Did you follow this:
no, i didnt need to rewire for the dizzy because the distributor that came on the motor was a 9 pin?
There's no ICM fuse.
Have you taken your ICM to an auto parts store to be tested?
Or if you have a multimeter, you can test it yourself:
http://www.team-integra.net/forum/bl...eshooting.html
strider380
13
10-25-2010 04:52 PM
alpha_1
03-10-2008 10:04 AM
D3U1LT
01-27-2005 12:24 PM
