check engine light
Old Oct 13, 2011 | 01:45 PM
Chavy340's Avatar
Post check engine light
How to check the check engine light codes on a 1990 honda accord using the engine light flashes?
Old Oct 13, 2011 | 03:49 PM
jdmcertified909's Avatar
Default Re: check engine light
Behind Passanger kick panel. Blue connection with two wire. Jump it with a wire paperclip whatever you can jump it with. Then turn on the key to III and watch the check engine flash
Old Oct 14, 2011 | 02:42 PM
Lost Again's Avatar
Didn't the 90 still have the led on the ecu..........unless someone has changed it...yes
EDIT: Also, that should be "on" or pos II on the key....III and it would be starting.
Old Oct 14, 2011 | 04:03 PM
Both my 1990 honda accords have the two wire plug behind the kick panel
Old Oct 14, 2011 | 05:17 PM
Lost Again's Avatar
Yes, just another way to get there......but it is still II, might want to edit your post so not confuse anyone in the future.
Dj prince Charm
Apr 16, 2018 04:39 PM
aspire
Jun 28, 2010 10:49 AM
SleeperGSR
Jul 15, 2007 10:05 AM
