help, my friend's car was smoking, and now won't start
Old 12-27-2003, 09:38 AM
itsJDMyo's Avatar
Default help, my friend's car was smoking, and now won't start
ok, my friend has a stock 92' honda civic dx and yesterday on his way home...his engine started to smoke pretty bad, it felt like it was gonna die, and right when he lifted his foot off the gas pedal, it died. and now, it won't start again. you can hear the car trying to turn on, but it can't. what could possibly happen??
Old 12-27-2003, 09:42 AM
EPIC TUNING
E-Rok's Avatar
Default Re: help, my friend's car was smoking, and now won't start (b00st)
check it for codes 1st.
uranazo's Avatar
did the temp gauge go up? if so id prob say it over heated...
Old 12-27-2003, 09:46 AM
itsJDMyo's Avatar
Default Re: (uranazo)
he was panicing at the time, and didn't really look at it, all he did was run out and opened the hood.
yea, but if it was overheated, shouldn't it start again once it cools down?
Old 12-27-2003, 09:51 AM
EPIC TUNING
E-Rok's Avatar
Default Re: (b00st)
maybe he jumped timing.
Old 12-27-2003, 09:52 AM
itsJDMyo's Avatar
Default Re: (rewsnaeht)
what do you mean by that?
Old 12-27-2003, 09:54 AM
EPIC TUNING
E-Rok's Avatar
Default Re: (b00st)
timing belt could have jumped a tooth and would cause it not to start again.
Old 12-27-2003, 09:59 AM
uranazo's Avatar
Default Re: (b00st)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b00st &raquo;</TD></TR><TR><TD CLASS="quote">he was panicing at the time, and didn't really look at it, all he did was run out and opened the hood.
yea, but if it was overheated, shouldn't it start again once it cools down? </TD></TR></TABLE>
not if something seriously fucked up ... or as stated above, the timing belt jumped a tooth...
Old 12-27-2003, 10:00 AM
itsJDMyo's Avatar
well, all he told me that there was just smoke. he didn't hear any weird noises or anything...and now the car won't start anymore
uranazo's Avatar
if the timing was jumped, whoa, depending on how much, u pretty much can say good bye motor... the whole head would probally be destroyed along with a good chance the bottom end...
Old 12-27-2003, 10:01 AM
JDM-97CX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uranazo &raquo;</TD></TR><TR><TD CLASS="quote">
not if something seriously fucked up ... or as stated above, the timing belt jumped a tooth... </TD></TR></TABLE>
Well if it overheated it would start again when it cooled down.
What color was the smoke? This sounds more to me like a blown head gasket than a car that has jumped timing. But it is still possible that timing is the case.
Old 12-27-2003, 10:02 AM
EPIC TUNING
E-Rok's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uranazo &raquo;</TD></TR><TR><TD CLASS="quote">if the timing was jumped, whoa, depending on how much, u pretty much can say good bye motor... the whole head would probally be destroyed along with a good chance the bottom end... </TD></TR></TABLE>
well i snapped my timing belt @5k and nothing happened to my motor.
then i did the timing belt at TDC but 180* off, holy **** the motor sounded horrible all i heard was valves slamming into the pistons
Old 12-27-2003, 10:06 AM
itsJDMyo's Avatar
the smoke was white and shouldn't oil be leaking from the engine if it was a blown headgasket though?
JDM-97CX's Avatar
Are you gay, english or retarded? If the timing jumped it doesn't mean your motor is gone. It may have very minor damage but that is easily fixed. More often than not when the timing jumps all that needs replacing is the timing belt and possibly the tensioner.
Old 12-27-2003, 10:09 AM
JDM-97CX's Avatar
Default Re: (b00st)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b00st &raquo;</TD></TR><TR><TD CLASS="quote">the smoke was white</TD></TR></TABLE>
White smoke is coolant burning. Sounds to me like it may have been the head gasket. Check the coolant levels in the car and see if they are below normal just to make sure it was coolant burning off and not some other little thing.
Old 12-27-2003, 10:10 AM
JDM-97CX's Avatar
Default Re: (b00st)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b00st &raquo;</TD></TR><TR><TD CLASS="quote"> and shouldn't oil be leaking from the engine if it was a blown headgasket though?</TD></TR></TABLE>
Not always. Normaly you will see more coolant than oil leakage.
Old 12-27-2003, 10:15 AM
itsJDMyo's Avatar
Default Re: (JDM-97CX)
he checked the coolang earlier and it was still full though, could it be a cracked radiator also?
Modified by b00st at 7:32 PM 12/27/2003
Old 12-27-2003, 10:18 AM
JDM-97CX's Avatar
Default Re: (b00st)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b00st &raquo;</TD></TR><TR><TD CLASS="quote">he checked the coolang earlier and it was still full though</TD></TR></TABLE>
Well maybe not much burned off. 9 1/2 times out of 10 white smoke is coolant burning off. I would let the car sit for a while and see if it will start when it is totaly cold.
onepoint-gsr
02-19-2006 08:54 PM
94_CRVtec
04-23-2005 10:26 AM
pbizzlegsr
07-07-2004 10:23 PM
queez
04-04-2004 05:21 PM
dj_eckonomics
05-05-2003 05:02 PM
Quick Reply: help, my friend's car was smoking, and now won't start
