help, my friend's car was smoking, and now won't start
1 Post
ok, my friend has a stock 92' honda civic dx and yesterday on his way home...his engine started to smoke pretty bad, it felt like it was gonna die, and right when he lifted his foot off the gas pedal, it died. and now, it won't start again. you can hear the car trying to turn on, but it can't. what could possibly happen??
1 Post
Re: (uranazo)
he was panicing at the time, and didn't really look at it, all he did was run out and opened the hood.
yea, but if it was overheated, shouldn't it start again once it cools down?
Re: (b00st)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b00st »</TD></TR><TR><TD CLASS="quote">he was panicing at the time, and didn't really look at it, all he did was run out and opened the hood.
yea, but if it was overheated, shouldn't it start again once it cools down? </TD></TR></TABLE>
not if something seriously fucked up ... or as stated above, the timing belt jumped a tooth...
if the timing was jumped, whoa, depending on how much, u pretty much can say good bye motor... the whole head would probally be destroyed along with a good chance the bottom end...
1 Post
Re: (uranazo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uranazo »</TD></TR><TR><TD CLASS="quote">
not if something seriously fucked up ... or as stated above, the timing belt jumped a tooth... </TD></TR></TABLE>
Well if it overheated it would start again when it cooled down.
What color was the smoke? This sounds more to me like a blown head gasket than a car that has jumped timing. But it is still possible that timing is the case.
Re: (uranazo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uranazo »</TD></TR><TR><TD CLASS="quote">if the timing was jumped, whoa, depending on how much, u pretty much can say good bye motor... the whole head would probally be destroyed along with a good chance the bottom end... </TD></TR></TABLE>
well i snapped my timing belt @5k and nothing happened to my motor.
then i did the timing belt at TDC but 180* off, holy **** the motor sounded horrible all i heard was valves slamming into the pistons
1 Post
Re: (uranazo)
Are you gay, english or retarded? If the timing jumped it doesn't mean your motor is gone. It may have very minor damage but that is easily fixed. More often than not when the timing jumps all that needs replacing is the timing belt and possibly the tensioner.
1 Post
Re: (b00st)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b00st »</TD></TR><TR><TD CLASS="quote">the smoke was white</TD></TR></TABLE>
White smoke is coolant burning. Sounds to me like it may have been the head gasket. Check the coolant levels in the car and see if they are below normal just to make sure it was coolant burning off and not some other little thing.
1 Post
Re: (b00st)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b00st »</TD></TR><TR><TD CLASS="quote"> and shouldn't oil be leaking from the engine if it was a blown headgasket though?</TD></TR></TABLE>
Not always. Normaly you will see more coolant than oil leakage.
1 Post
Re: (b00st)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b00st »</TD></TR><TR><TD CLASS="quote">he checked the coolang earlier and it was still full though</TD></TR></TABLE>
Well maybe not much burned off. 9 1/2 times out of 10 white smoke is coolant burning off. I would let the car sit for a while and see if it will start when it is totaly cold.
