help... car wont start
Old 10-04-2006, 12:43 PM
$G-Rat$'s Avatar
Default help... car wont start
swapped a 95 ls into a 95 coupe
- have power, have ecu hooked up, have fuel, fuel pump primes, brand new dizzy, new spark plugs wires nd spark plugs, have lights, just wont turn over
if anyone can help i would greatly appreciate it......
Old 10-04-2006, 12:45 PM
philosofy1's Avatar
Default Re: help... car wont start (TTC609)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TTC609 &raquo;</TD></TR><TR><TD CLASS="quote">swapped a 95 ls into a 95 coupe
if anyone can help i would greatly appreciate it......</TD></TR></TABLE>
when you say brand new dizzy, did you double check the timing? also, how is the starter? is it clicking?
Old 10-04-2006, 12:47 PM
$G-Rat$'s Avatar
Default Re: help... car wont start (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">when you say brand new dizzy, did you double check the timing? also, how is the starter? is it clicking?</TD></TR></TABLE>
yea the starter is clicking and it sounds like it wants to go but nothing, didnt check the timmimg, how can i do that without a timming light?
Old 10-04-2006, 12:55 PM
philosofy1's Avatar
yea the starter is clicking and it sounds like it wants to go but nothing, didnt check the timmimg, how can i do that without a timming light?</TD></TR></TABLE>
before even getting to the distributor part, are all yout grounds bolted down. the car won't start if there is no grounds.
Old 10-04-2006, 08:00 PM
$G-Rat$'s Avatar
yea im sure all the grounds are there i checked that a million times but ill got over that again....... anything else????/
thanxs
Old 10-04-2006, 08:01 PM
Syndacate's Avatar
Prolly don't wanna hear this..but it sounds like a bad ground..
If you're POSITIVE then you might wanna look at temporarily swapping out the starter and seeing if that's it.
Old 10-05-2006, 08:52 AM
$G-Rat$'s Avatar
Default Re: (Syndacate)
does anyone know how many grounds there actually are??
Old 10-05-2006, 02:24 PM
$G-Rat$'s Avatar
Default Re: (TTC609)
bumpp...
anyone with any helppp ive gone through the same checklist 500 times, any advice please...
thanxs
Old 10-05-2006, 02:28 PM
philosofy1's Avatar
i only know of 3.
1. the one that bolts to the tranny.
2. the one that bolts to the valve cover.
3. the one near the thermostat housing.
Old 10-05-2006, 02:32 PM
Slamaccord's Avatar
Default Re: (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">i only know of 3.
3. the one near the thermostat housing.</TD></TR></TABLE>
Sounds good to me.
Make sure you have enough battery voltage.
Make sure your battery terminal connections are tight and clean.
Old 10-05-2006, 03:17 PM
92ehatch's Avatar
Default Re: (Slamaccord)
make sure none of your grounds are broken. there was a thread last week where someone couldnt get their car started, and the grounds looked good, but one of the wires was actually broken where you couldnt see it.
Old 10-05-2006, 03:20 PM
1992Si's Avatar
Take the starter back out and put it back in. I have had to do this on two engine changes.
Then plan on buying a rebuilt starter soon.
Old 10-05-2006, 04:43 PM
Slamaccord's Avatar
Default Re: (1992Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1992Si &raquo;</TD></TR><TR><TD CLASS="quote">Take the starter back out and put it back in. I have had to do this on two engine changes.
Then plan on buying a rebuilt starter soon.</TD></TR></TABLE>
What exactly does this do?
I'm curious.
Old 10-06-2006, 12:47 PM
TriniTech's Avatar
sounds like you need a starter, this is dumb, but have you tried changing the battery?.
Old 10-08-2006, 01:20 PM
DB1_559's Avatar
yo.did.you.take.the.head.off.just.got.mine.started .yesterday.valves.was.all.of.spec
Ek9_Cuhzz
03-02-2012 08:23 AM
lilmisshonda
07-02-2008 06:43 AM
edsymister
07-27-2006 06:31 PM
lazykiwi
05-13-2004 11:55 PM
JBG's Ferio
07-30-2003 06:41 PM
Quick Reply: help... car wont start
