help: can't open my crank pulley bolt on my b16
Old 07-22-2009, 06:03 AM
skyvang's Avatar
Default help: can't open my crank pulley bolt on my b16
i have ran out of idea and broken all my big wrench and other tools..i was wonder is there any way i could open this crank pulley bolt?
Old 07-22-2009, 08:02 AM
kp
kp's Avatar
Default Re: help: can't open my crank pulley bolt on my b16
Impact gun and a torch.
Old 07-22-2009, 08:05 AM
thi3v3z's Avatar
you could buy the $40 tool and it will come right off with an air impact.
Old 07-22-2009, 08:07 AM
parce85's Avatar
3/4 impact gun will take it off with hardly any effort
Old 07-22-2009, 09:09 AM
1992Si's Avatar
Or take it to a shop and have them remove it and give the guy $10.00
Old 07-22-2009, 09:55 AM
skyvang's Avatar
thanks for the help....i took to the shop and there impact gun are too weak and other shop charge me $85 and its not %100 sure they going to open it.....i guess i'm screw heeh
Old 07-22-2009, 10:18 AM
Anton LaVey's Avatar
or you could try to remove the bolt instead of trying to open it hahahah
Old 07-22-2009, 10:23 AM
93preludeh22's Avatar
Go to a place that works on big trucks.. they'll be able to get it off no problem
Old 07-22-2009, 10:31 AM
philosofy1's Avatar
I know it's not the best or recommended way, put you can put a screwdriver at the flywheel then try to remove the bolt. Again, it's not the best way being that it can damage the teeth on the flywheel, but it might get the job done.
Old 07-22-2009, 04:07 PM
shawn_crx's Avatar
impact guns won't work. My bro-n-law accord had the same issues, took it to a shop that has 1000 ft lbs guns, and still won't work. Then we took it to a honda repair shop and they raise the car up and use a 3/4 breaker bar with a long cheater on it. "Bingo"
donate 40 to the 1000 ft lbs gun shop for his tries
The honda shop did it for free.... :-)
Old 07-22-2009, 04:19 PM
skyvang's Avatar
thanks for helping me out....
Old 07-22-2009, 04:24 PM
lponcian5799's Avatar
torch, breaker bar, and beer.
Old 07-22-2009, 04:48 PM
EGR95's Avatar
try a long pipe or use ur legs it work with me.
Old 07-22-2009, 06:32 PM
Rok_Stok's Avatar
You need an impact wrench, it took a huge Blue Point to get mine off.
Old 07-22-2009, 06:35 PM
TheJGB3's Avatar
I was taught to ALWAYS use the RIGHT TOOL FOR THE JOB!!
Powerbuilt 648796
buy it here for $24.99
http://www.amazon.com/Powerbuilt-648...8316488&sr=1-1
Old 07-22-2009, 07:34 PM
Rok_Stok's Avatar
The 2-year lab, here at Pitt State, couldn't find that part, so us in the 4-year lab just did it with a big impact. But you're right, if you have the option of using the right tool, then use it.
Old 07-23-2009, 06:04 AM
skyvang's Avatar
thanks for the help, using a long pipe and use my feet is a good idea but since the dang bolt is too tight, it either break my tools or bend my tools. this bolt is not a joke....i use my friend impact gun about 150 psi..still would not open it..i need a impact that could reach up to 200 psi or up......i guess i need to go and try to find a place where they work on big truck...do anybody know a name for repair shop for big truck?
Old 07-23-2009, 06:35 AM
instrument's Avatar
yes, steves shop, but seeing we don't know what country/city/state you're in steve may not be close to you.........
motoxpaul05
10-08-2016 07:10 PM
Layne Barber
04-17-2015 12:38 PM
Yolandita
05-21-2006 06:54 PM
hatchdrvr
02-13-2003 09:51 PM
hatchdrvr
02-13-2003 04:07 PM
Quick Reply: help: can't open my crank pulley bolt on my b16
