header question....
Old 11-09-2006, 10:31 PM
imacoolkid's Avatar
Default header question....
hey guys. i have a 2000 civic si with the gsr swap just completed. i have a dc b series header but it will not clear th eoil pan on the b18c motor. is there a slight difference in size, length, bend etc from a b16a header to a b18c? thanks
Old 11-10-2006, 04:36 AM
imacoolkid's Avatar
Default Re: header question.... (cmillertime05)
anyone
Old 11-10-2006, 04:52 AM
f20bej1's Avatar
the gsr header is longer in lenght yes.
Old 11-10-2006, 05:01 AM
Former Moderator
B18C5-EH2's Avatar
Your B16A header is too short because the block itself is shorter than the GS-R block, so companies make the header shorter height wise.
Do yourself a favor and buy a header for a Type R - it's the only one that will fit right.
If you buy a GS-R header it will clear your oil pan height wise, but it won't bolt up to your cat convertor because the length of the pipes themselves after the bend to clear the pan is too damn short to reach, and there is no oxygen sensor bung in a GS-R header because the GS-R has both of it's oxygen sensors in its catalytic convertor, unlike your car which has one in the header, one in the cat.
Old 11-10-2006, 07:15 AM
imacoolkid's Avatar
Default Re: header question.... (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">Your B16A header is too short because the block itself is shorter than the GS-R block, so companies make the header shorter height wise.
If you buy a GS-R header it will clear your oil pan height wise, but it won't bolt up to your cat convertor because the length of the pipes themselves after the bend to clear the pan is too damn short to reach, and there is no oxygen sensor bung in a GS-R header because the GS-R has both of it's oxygen sensors in its catalytic convertor, unlike your car which has one in the header, one in the cat.</TD></TR></TABLE>
wow thanks for this information looks like il be buying a type r header and selling a dc header for b16 thanks guys
slow91crx
29
06-12-2006 01:53 PM
Cesare1987
11-07-2005 09:59 AM
allmotorgsrcivic
09-29-2005 01:49 PM
whiteJDMdc2
07-02-2003 09:03 AM
HondaGSR
01-16-2003 07:49 PM
Quick Reply: header question....
