GSR OBD2 Problem=== Plz Help
My car is bouncing between rpms when i give it gas. I have changed the IACV EACV and ECU and went through about 10 harnesses. Im still throwing the P1508 after changing these units and I have now received a TPS code. I changed my throttle body for a new edlebrock 64mm with a new tps on it. That cleared it up but i still got this problem. I cant rev over like i think 4K and i cant drive it cause its too limp. I cant even reach vtec or nothing. Please help wit suggestions and flaming isnt necessary. GSR info is low at the moment so this is my last resort.. thanks
Re: GSR OBD2 Problem=== Plz Help (thewonderer)
are you sure it's not your dizzy? crank sensor?
I don't have an obd2 car, but that sounds like what my DA did when the dizzy went out.
good luck
VIc
good luck
VIc
The problem was a bad harness. I changed harnesses with a new one from honda and car functions perfectly. I swapped motors afterwards and the little hatchy pulling a 14.2 with a stock b16a2. thnks
crnimacak
01-19-2006 04:59 PM
speedy108
12-18-2005 05:50 AM
