GSR in my 92 cx
GSR in my 92 cx
I got my 98 gsr in my 92 cx hatch. I'm using the cx harness, not everything plugs up. I already cut and spliced the injectors, i repinned the distributor, im not to sure about the alternator though, the plugs were different and the wires were different colors, i need some help on that if anyone has done it before or has a schematic for me. Othere than that everything is in and ready to go, just have to run the 7 wires that arent on the cx harness that are nessacry for the gsr.
Former Moderator
Re: GSR in my 92 cx (EGb18cT)
Dude!
USE the GS-R harness - it PLUGS right into the Civic harness on your right soide strut tower area!
Then you can use the GS-R injectors and distributor.
I've done 3-4 swaps where the engine was a B18C1 or B18C5 with the "OBDII" harness and I PROMISE you it all plugs in. You will have a few extra plugs left over on the Teg harness, because they have ABS and a few extra sensors, but it will be fine.
From there just find an OBDI 1994-1995 P72 GS-R ECU and you will still be OBDI and there will be no need for a jumper harness and an OBDII P72 from the 1996-up GS-R.
Did you even try to plug in the Integra engine harness?
No need to "cut and splice" anything bro!
Try it - you'll thank me later
[Modified by B18C5-EH2, 2:57 PM 3/23/2002]
I did try using the obd 2 harness and it worked, i was just scared that i would fry something. Never heard of anyone being able to plug obd2 into a obd1 car. Ive already cut up the harness, that ****** sucks. Anyone have a obd2 harness laying around?
96MidoriHatch
16
12-23-2004 01:15 PM
Mischief_EG
15
06-15-2004 07:56 PM
