GSR F/R Brake Swap on an EK
i've searched and can't find any valuable help. i know for a fact gsr brakes bolt up to EG's like stock.. but what about ek? i hear it'll throw off the front camber or something and it doesn't lineup.. will the dc2 ebrake cables work in an ek or do i need si ones??
Re: GSR F/R Brake Swap on an EK (bolsaman)
it will work but it will get a lil tight due to the bigger size in ebrake line where u put the ebrake cable in, ull have to flare it and install it will take a while i guess
and yeah gsr trailings will fit from front and rear bolt on but yeah it will throw the camber out a lil bit .. i forgot how or what but its basically because their trailing arms stick out more but it bolts right on
yeah there's a lot of difffernece especially in high speed braking but u wont notice much if uve always driven a car with disk brakes but u will surely not notice the drum brakes anymore
I've got the same set up in my 99 civic, GSR brakes all around. It fit like a glove. The front has a little negative camber but thats because of the drop. Make sure you use your rear lower control arms from your civic, the integras are longer. The e-brake cables also fit but tightly.
Ek Forever y0!
Re: GSR F/R Brake Swap on an EK (ek99civic)
Oh, where did this come from, I almost looked right over it.
Suspension/Brakes:
https://honda-tech.com/zerothread?id=152884- Putting X Brakes on Y Car
https://honda-tech.com/zerothread?id=514109- 96-97 JDM ITR 4 Lug Brake Information
https://honda-tech.com/zerothread?id=811892- ITR 4 Lug onto EK
https://honda-tech.com/zerothread?id=514109- ITR Brake Thread
https://honda-tech.com/zerothread?id=333061- Five Lug Conversion
https://honda-tech.com/zerothread?id=1036267- GSR Suspension into EG
https://honda-tech.com/zerothread?id=812062- Integra Rear Discs onto EG
https://honda-tech.com/zerothread?id=820484- Full Brake Swap for EG
https://honda-tech.com/zerothread?id=641639- EK Rear Disc Conversion
https://honda-tech.com/zerothread?id=1513752- How to put X Brake Setup on an EK
https://honda-tech.com/zerothread?id=641639- Complete Rear Disc Brake Conversion
https://honda-tech.com/zerothread?id=1030365- Integra Brake Swap
Suspension/Brakes:
Leb_CRX
12-20-2005 12:58 PM
lowgman
01-16-2005 07:19 PM
GoldenONE
13
04-19-2003 03:36 PM
