what e brake cables do i use for an ek and gsr rear brakes(searched already)
what e brake cables do i use for an ek and gsr rear brakes...just wondering but how come you cant use the stock ek cables??
Modified by D Spec Dc2 at 1:12 AM 4/19/2003
Re: what e brake cables do i use for an ek and gsr rear brakes(searched already) (D Spec Dc2)
I used GSR ones, but some people cant get them to work. You shouldnt have a problem with SI cables.
i'm gonna go out and buy new cables...should i try the gsr or just get the si
you can try the gsr if you can get them cheaper at a junkyard, but then if they don't work you have to get si..... good luck, l8rz
Re: what e brake cables do i use for an ek and gsr rear brakes(searched already) (buddha429)
junk yard = $30
test before u buy, make sure nothing is bent at teh endlinks.
Re: what e brake cables do i use for an ek and gsr rear brakes(searched already) (EKology)
My GSR cables just bolted up to my 96 hatch without issue.
Re: what e brake cables do i use for an ek and gsr rear brakes(searched already) (tonyXcom)
danny u cant use stock ones cause the drum cables are different than the disc. i just got my gsr cables for $40
Im using gsr brake lines too, however i ran into a problem called "Wrong ABS sensor"
dck1ng69
01-01-2018 12:57 PM
lowgman
01-16-2005 07:19 PM
