ek with a d16z6 starting problems
my buddy has a ek hatch and ive been helping him with a d16z6 swap and we have it all in and hooked up but we are not getting any spark or fuel hes running a y8 harness with a chipped p28 . we tryed to swap the ecu with a stock p28 and still nothing. could it be his main relay? it ran and drove perfectly fine before we pulled the y8 out
Re: ek with a d16z6 starting problems
Check all your fuses under the Hood and in the car. Check the main battery 80 A fuse under the Hood ... does the car even get power to the cluster?
make sure all your grounds are clean sand the connections. one is on the valve cover to the radiator support and the trans mission to the frame rail. i had this happen once . i had powerto everything and the starter would just click and wouldnt turn over.
salvi2dafullezt
08-12-2013 06:47 PM
gotnos2
09-28-2007 09:27 PM
HTLuver
27
08-03-2006 10:37 AM
