93 Del Sol/B17 swap -- No prime on fuel pump!!?
Hey guys finally decided to make an account start a topic after searching through many threads and forums with no solution.
Here we go;
B17 in Del Sol, was running then changed the following; Skunk2 Intake mani, skunk2 fuel rail, Aem FPR, aem fuel filter, new ecu (went from p06 or p05 cant remember to a p30), and a different engine harness.
Problem- Fuel Pump Won't prime
What I tested and know- Replaced the main relay and it clicks once
-Fuel pump can be turned on by jumping connectors 5 and 7 on main relay connector
-Throwing what seems to be a check engine code 10 maybe 1?
-Did a K-Test on Ecu and got 5V at Map Sensor
-Tested ICM
-Replaced fuel pump (Airtex to walbro)
-Checked all fuses
-Checked ground on thermostat and cleaned.
Any help is greatly appreciated
Here we go;
-Tested ICM
-Checked all fuses
Re: No prime on Del Sol fuel pump!!?
Is the G101 ground on the thermostat housing connected, clean, and tight?
If you unplug ECU connector A, turn the key to ON(II), and then ground terminal A7 or A8 in the unplugged connector, does the fuel pump run?
I grounded both the connectors A7 ad A8 at separate times and they both kicked the fuel pump on
Turn the key off and unplug ECU connectors A and B. Do terminals A26 and B2 in the connectors have continuity to body ground?
Now turn the key to ON(II). Do terminals A25 and B1 have battery voltage to body ground?
I am getting very low amounts of voltage in A25 and B1 (about .3V) and very low resistance as well in A26 and B2 (about .2 ohms)
Re: 93 Del Sol/B17 swap -- No prime on fuel pump!!?
I saw a spark when i first started testing then nothing after so I checked the fuses and noticed I blew out the 15A fuse in the engine bay for the ECU when testing the voltage.
http://www.phearable.net/tech/wiring...schematics.gif
Don't look back. Make sure you are probing the correct ECU connector terminals and try again.
A25 9.6V
B1 9V
Both B2 and A26 have continuity to ground
I tried retrieving my check engine light code for this problem and the light continuously blinks every 5 seconds until I take the jumper wire out then it is solid. What would this indicate?
All Hondagirl
12
08-06-2016 12:52 PM
86aw11
12-24-2015 08:18 AM
civic2liters
06-01-2008 08:11 PM
