d16 shift forks
d16 shift forks
Alright, I have seen numerous times that 92-95 ex/si transmissions had aluminum shift forks, and the 96-00 ex tranny had steel shift forks. Now since the steel forks are stronger, obviously you want a 96-00 tranny. However, I was wondering, could you just swap forks alone, instead of buying a whole tranny, just get the steel fork and use it in you 92-95 trans?
Re: d16 shift forks (piscorpio)
from all the info i've read and heard, you cannot swap forks. Gearing is better on the Z6 tranny, but like you said fork is stronger on Y8 tranny
Re: d16 shift forks (JaeOne3345)
Curses! Foiled again! Seemed like it would be such a simple thing. Are the z6 trannies really geared better though? I never knew that, I assumed they were the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by piscorpio »</TD></TR><TR><TD CLASS="quote">Curses! Foiled again! Seemed like it would be such a simple thing. Are the z6 trannies really geared better though? I never knew that, I assumed they were the same.</TD></TR></TABLE>
i dunno if the z6 tranny is geared better but i know mines is (going to be) *srr final drive 4.9 sitting here right next to me *. z6 trans in the garage. how much more lazy should i get?lol
Re: d16 shift forks (RSZero1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RSZero1 »</TD></TR><TR><TD CLASS="quote"> Gearing is better on the Z6 tranny</TD></TR></TABLE>
Technically, yes, but you should mention that it is nothing worth grumbling over. The only difference is the Z6 has a 1.900 2nd gear and the Y8 has a 1.909 2nd gear. Everything else is the same. You would never notice the difference. I would rather have the steel shifter forks.
Re: d16 shift forks (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 »</TD></TR><TR><TD CLASS="quote">
I would rather have the steel shifter forks.</TD></TR></TABLE>
I wonder how much a custom made unit would cost...hmmmm.
D Tranny Guru
The forksets don't interchange. The little ball bearings for the shift stop notches are in the fork assembly on the 92-95, but in the tranny case on 96-00.
You must remove the check ***** before spliting case or you will lose them! I was quoted $300-350 PER shift fork to be custom made.
Re: d16 shift forks (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone »</TD></TR><TR><TD CLASS="quote">The forksets don't interchange. The little ball bearings for the shift stop notches are in the fork assembly on the 92-95, but in the tranny case on 96-00.
You must remove the check ***** before spliting case or you will lose them! I was quoted $300-350 PER shift fork to be custom made.</TD></TR></TABLE>
Yikes!! Thats more than 3 times the cost of the tranny in many cases. I had a feeling it would not be worthwhile. Thanks for your input mista bone.
ieatrice
10
02-15-2006 11:13 AM
GdmLaz
26
11-15-2005 02:23 PM
Kyles ej1
10
09-23-2004 01:14 AM
